Any Springer guys have this happen
Old Sep 5, 2017 | 08:03 AM
Superfly3176's Avatar
Superfly3176
Nothing on the rotor or that area. May have been debris but I'm not sure. There's a torx bolt you cant see in the picture
​​​​​​On the front end that looks like may have caught the fender and started the chain of events.
I'm going to replace it with a flat bolt as this one seems to protrude enough to make me wonder if it wouldn't happen to the next fender.
Old Sep 5, 2017 | 08:56 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Yeah that must have been one hell of a pothole. Looks like the mount for the dog bone for the front suspension got caught up under the fender and just ripped it out. Tough break on that got to watch em potholes man.....
Old Sep 5, 2017 | 11:59 AM
Tom84FXST's Avatar
Tom84FXST
No debris did that...that bolt on the end of the dogbone did.
Old Sep 5, 2017 | 12:02 PM
98hotrodfatboy
I would also check the rear suspension...... that must have been one hell of a hit.......
Old Sep 5, 2017 | 12:13 PM
Cousy's Avatar
Cousy
Happens more often than it should. Tom nailed the issue. Are you the same guy who posted on the HSOA forum?
Old Sep 5, 2017 | 12:28 PM
0maha's Avatar
0maha
I bet you're right.
Wow!
Old Sep 5, 2017 | 02:24 PM
Superfly3176
Yeah sadly I knew the pothole was there too i just derped. There's a bolt in the next middle of the dogbone there that looks like it got caught as well. I'm gonna see if I can find anything lower profile...
Old Sep 5, 2017 | 03:16 PM
Cousy's Avatar
Cousy
Some on the HSOA forum have ground the hex head down to about 50% thickness, leaving just enough for a wrench. Or grind all but two sides off so a wrench will still hold it. Maybe you can find a button head bolt with a torx or Allen head.
I would be sure that your front end is properly adjusted. Check your shock, rocker drag, and rebound spring adjustment.
Old Sep 5, 2017 | 06:24 PM
glidein wide's Avatar
glidein wide
Like I said back in post five,clearance issue,some Napa stores carry chrome hardware and flat head Allan bolts,torques bolts. Check the flare also on replacement fender or repaired fender after installing.
Old Sep 5, 2017 | 07:54 PM
98hotrodfatboy
WHo????
