How far away is home? Pull the headlight connector off the headlight and you'll likely make it. If you don't ride home at night.
i'm 37 miles, I have everything turned off that I can turn off...my switch to light up the brakes is out on my rear break (so it doesn't activate the tail lights when I use rear brake only) and my drive is mostly open 4 lane....I got my fingers crossed I can make it LOL If not, my wife has my truck keys and knows how to hook up a trailer. It will just delay my beer drinking to have to sit on the side of the road and wait for her.
Man, so it seems like my Ultra is just giving me so much **** lately.
Recently fixed the ignition coil, and now riding to work this morning my voltage gauge dropped down 10v....So I shut down everything electrical that I could, and no improvement. It just kept falling mile after mile until it was finally bottomed out at 8v. I had to stop for fuel, and when I started again there was a noticeable lag, like the battery is dying. I got to work, and I had my battery tender with me, so it's plugged in and charging now. So I know I need to get a voltmeter and do some testing but i can't right now. Hoping 8-9 hours on the tender will at least get me 37 miles back home so I can figure out if it's the battery or the stator. Hoping it's the battery just no longer accepting a charge, but i'm sure I won't be that lucky.
god I hope it isnt the stator. That seems like a bitch to replace.
I was having electrical problems with my 1996 Ultra Classic, it turned out to be ground problems, I made a grounding kit, I ran a 8 ga wire from the neg post on the battery, to the engine and to the fairing brackets, have not had any problems since.
I am going to check my grounds tonight, if I make it home without a trailer. If I end up waiting on the side of the road, i'll just go home and drink beer LOL
Take a cold drink with you when you leave.
That way you are prepared for the wait and your bike will get you all the way home!!!!
Pull your battery and take it it an auto part store and have them do a load test. Just because its showing 12.5 dont mean its good. 12.7 is full charge
