Voltage Issues
Old Sep 24, 2017 | 09:14 AM
  #41
02Deuces's Avatar
02Deuces
Well put the harley parts on still no charge I'm at a loss
Old Sep 24, 2017 | 09:18 AM
  #42
Dr.Hess's Avatar
Dr.Hess
Please post the results of the sticky tests.
Old Sep 24, 2017 | 09:31 AM
  #43
02Deuces's Avatar
02Deuces
Battery 12.6v off
Start drips to 11.6v
Rev to 2500 rpm no change
Turn lights on drops to 11.5v
Scale on 20k ohms showing 0 from stator plug
On a.c. volts I'm showing 26.6 running. But its a brand new harley regulator
Old Sep 24, 2017 | 09:42 AM
  #44
WP50's Avatar
WP50
Where are you getting this reading from? Hows the meter connected to the bike? Please
WP
Old Sep 24, 2017 | 09:48 AM
  #45
02Deuces's Avatar
02Deuces
Right off battery terminals
Old Sep 24, 2017 | 09:58 AM
  #46
WP50's Avatar
WP50
Umm can you do this test from doc's sticky
Set meter to AC Volts, 100V scale. Attach each meter lead to a stator pin. You may need to rig up some type of temporary plug. It is important that nothing can short to ground or to each other accidentally, or you will blow the stator if it wasn't blown before. An old plug off of your last regulator is a good way to do it, but, get creative and be careful. I can do it holding the leads on the pins once the bike is running, but I don't like to. Start bike. Voltage should vary with engine speed. Specs are in your shop manual, but 35V at a couple thousand RPM is probably about right. My book says 19-26 V / 1K RPM.
An extra person on the throttle is very helpful
WP
Old Sep 24, 2017 | 10:14 AM
  #47
WP50's Avatar
WP50
dang Has me thinking to hard this morning LOL
"Scale on AC Volts, generally a lower setting (might be 20V, or 100V). Check across the battery when the bike is running. If you get any significant reading, like 10V or 15V AC, the diodes in the regulator are shot. This is a pretty rare failure point, but it has happened to me. Another sign of this is a strange behaving tachometer."
WP
Old Sep 24, 2017 | 10:22 AM
  #48
02Deuces's Avatar
02Deuces
Its a brand new regulator from harley
Old Sep 24, 2017 | 10:28 AM
  #49
WP50's Avatar
WP50
sent ya a PM
WP
Old Sep 24, 2017 | 10:37 AM
  #50
02Deuces's Avatar
02Deuces
Soooo I'm dumb. I left the cup off that stator....its charging now.
