Fuel valve question
Old Jun 16, 2007 | 12:45 AM
96 Wide Glide's Avatar
96 Wide Glide
Default Fuel valve question
Any need to close the valve when parking a 96' 80 evo?
From what I've read, the valve needs engine vaccuum to open anyway's, so the chances of flooding the carb should be slim.
Thx... Ben.
Old Jun 16, 2007 | 12:55 AM
mtnlvr's Avatar
mtnlvr
Default RE: Fuel valve question
I only closed mine in order to run the float bowl dry. Now I've got an aftermarket without the vac operation so whenever I remember I'll shut it off. The lack of the vac valve makes it easier to drain the tank for removal.
Old Jun 16, 2007 | 10:11 AM
WIEVORIDER's Avatar
WIEVORIDER
Never had it happen, but remember rubber diaphrams in the valve get old. Should the valve stick open,it can overflow the carb,and fill the engine. Unlikely to happen,ussually when the valve goes bad,it won't open leaving you stranded. Remember what can go wrong will. HD insalled the valve for a reason,and good habit to get into. I went to a Pingel valve for a S&S carb,and now have to shutthe valve off .It doesn't take too long to re-train yourself.
Old Jun 16, 2007 | 11:42 AM
pococj's Avatar
pococj
Vacuum operated petcocks = stupid (EPA idiots). Sooner or later the valve will fail. It'll probably fail in the closed position and strand you somewhere far from home, though. If it fails open, or starts leaking by, the odds are your carb float valve will notice it, and decide, "Hey, this is a great time to stick open, too!" Since newer carbs don't have overflows (EPA idiots, again) the gas will then drain into your engine, wash all the oil of the cylinder walls, accumulate in the crank case, then be drawn into the oil tank and/or be puked out the breather. Oil dilution happens, and your cylinder walls are worn the next time you start up. If you're really unlucky, the gas builds in the combustion chamber and when you start the motor the pistons try to compress it. They can't compress a liquid so something breaks.
All this is somewhat tongue-in-cheek. But it has happened.Gas diluted oil is bad, and oil washed off the cylinder walls is worse.
Shutthe valve.
Old Jun 16, 2007 | 01:08 PM
MikeyB's Avatar
MikeyB
That has happened to me, and it's a mess. I will never ever forget to shut off the petcock valve again.
MikeyB
Old Jun 16, 2007 | 10:43 PM
MJ's Avatar
MJ
I agree with above. Close it when you park it. By constantly turning your petcok you are also keeping the seals more pliable.
Arend
Engine Mechanical Topics
Feb 19, 2015 04:41 AM
RicRides
Feb 9, 2015 12:09 PM
gussound
Shovelhead
Feb 22, 2010 12:38 PM
38knuckle
Shovelhead
Apr 3, 2008 06:20 PM
socobandit
Ironhead
Jul 20, 2007 10:22 AM
