Vacuum hoses
Old Jan 7, 2018 | 09:05 PM
Jakzen's Avatar
Jakzen
Default Vacuum hoses
So, I'm in the middle of rebuilding my top end and am a little lost. There are two vacuum lines that come off the carb/manifold (S&S Super E). The line on the manifold goes to a tee, one leg goes to a vacuum switch, the other leg goes to the petcock. The second line comes off the bottom of the carb. Stock carb has similar setup. For the life of me, I can't figure out what this line is for.
Old Jan 7, 2018 | 09:20 PM
0maha's Avatar
0maha
Sounds like the second line is your overflow.
Old Jan 7, 2018 | 09:47 PM
Jakzen's Avatar
Jakzen
it might be, I was looking at it on their website. A labeled pic shows an overflow. Thank you for the response.
Old Jan 7, 2018 | 10:13 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Yep it's your overflow.
As for the others I suggest you get rid of that stock petcock and get a Pingel that way all you need is one hose going to your VOES (the vacuum switch)
Old Jan 8, 2018 | 05:09 AM
grbrown's Avatar
grbrown
There are alternative cheaper fuel taps available similar to the vacuum one, but without the vacuum feature. You avoid problems that a vacuum tap can give, while gaining control of fuel supply. Just get into the habit of turning the tap off when parked (same applies to a fancy Pingel)!
klkordzi
EVO
Apr 13, 2019 05:54 PM
jetdoc3037
Dec 16, 2015 04:26 PM
All Aces
EVO
Jul 24, 2014 05:58 PM
DoomedFailure
Mar 26, 2013 08:13 AM
packmn
Exhaust System Topics
Mar 31, 2009 09:05 AM
