Front end wobble question
Old Feb 13, 2018 | 03:49 PM
  #41
misfitJason's Avatar
misfitJason
Originally Posted by texashillcountry
No...I bought the $10 tool from Drag Specialties.
This is the same tool from J&P
https://www.jpcycles.com/product/910...xoCtMgQAvD_BwE
that's what I use too. I like that tool but it works even better when you have a second set of hands to help you torque the axel so it doesn't un-true itself after you align it. I feel your pain, my bike always feels like it is angled to the left when I am riding on it and I for the life of me can't figure it out.
Old Feb 13, 2018 | 03:52 PM
  #42
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Does it track straight when you let go of the handlebars?
Old Feb 13, 2018 | 07:08 PM
  #43
misfitJason
Yes for a moment then it wants to pull right. This is the part I don't know why. The real wheel is all setup with oem spacers appropriate for the wheel and bike. The front wheel uses a speedo drive for a 16 inch (which I have) which sets the spacing and the wheel is perfectly straight. The rear is perfectly aligned but no matter what it pulls right
I even checked the adjustment of the rear shocks. They are even and adjusted with the same preload. The front end is straight and was all new parts except for the triple trees, which I bought used, but not off a wrecked bike.
The only things I question are the tire on the back, which I am going to switch out after bike week as it's old and harder than I like, and the shocks. The shocks are oem ones but I had one and had to get another one to make a set when I built the bike. I have been looking for a takeoff set of used ones but I haven't had any luck at the local swapmeets or ebay to rule them out yet
The frame was new when I got it. The swingarm was used and looks straight to me when the axel is put through. I do have a spare swingarm sitting in the attic should the need arise.
I am about to give up on it and take it to my buddies shop and drop it off. I'll tell him to find it. I just hate paying for something I can do myself. But I also hate not being able to figure a problem out on my own. Sometimes you've got to get a second set of eyes on it
And mind you, I am checking all these things and only have partial blurred vision in my right eye due to an old accident. It's like seeing double all of the time, but I don't even drink! Haha
Old Feb 13, 2018 | 07:39 PM
  #44
texashillcountry
Dirt don't hurt
My Heritage did the same thing when I got it.
I took it to the Harley shop and was told "They all do that".
I finally got it straightened out when I put a touring mag wheel on the front for my dual disk brakes.
I had to play with the spacers on the left side a bit to get it to work.
I think you will find that if you space out your speedo drive just a bit then your bike will run straight.
Old Feb 13, 2018 | 08:35 PM
  #45
misfitJason
What did you space it with Tex?
Old Feb 13, 2018 | 08:43 PM
  #46
texashillcountry
Dirt don't hurt
A buddy of mine had a bag full of shims that would fit a 3/4" axle.
I have no idea where he got them.
I just called him and he doesn't remember where he got them either but he suggested going to a nut/bolt warehouse and seeing what they have.
Old Feb 13, 2018 | 09:03 PM
  #47
misfitJason
I have a good hardware store in mind. Any idea the approximate size?
Old Feb 13, 2018 | 09:28 PM
  #48
Prot's Avatar
Prot
Originally Posted by Spanners39
I'm saying nothing on the grounds it might define or incriminate me...
I did not have sexual relations with that tranny, Mrs. Five Speed.
Old Feb 13, 2018 | 10:10 PM
  #49
texashillcountry
Dirt don't hurt
If by size you mean thickness I don't think it'll take much to fix your problem.
It was a couple of years ago when I did mine and I just tried different thicknesses until I found the combination that worked.
Old Feb 14, 2018 | 07:03 AM
  #50
98hotrodfatboy's Avatar
98hotrodfatboy
Keep in mind that all roads are crowned for water to flow off the surface. Only car alignments are manipulated to stay straight on a crowned road. We cannot adjust for caster or camber....
