Front end wobble question
Old Feb 14, 2018 | 07:13 AM
  #51
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Keep in mind that all roads are crowned for water to flow off the surface. Only car alignments are manipulated to stay straight on a crowned road. We cannot adjust for caster or camber....
While what you say is true about the crowning, caster and camber there is nothing to keep us from adjusting our bikes to have them run straight.
Centrifugal force wants our bikes to stand up straight and with minor adjustments we can get them running straight.
I know because I did it.
I knew it was possible because the Hondas I had before my first Harley went straight when I let go of the bars.
Old Feb 14, 2018 | 12:21 PM
  #52
FreedomRider's Avatar
FreedomRider
I know when I have my bike on a lift the front is slightly turned to the right ... I guessed it was due to the clutch cable pushing it that way.
Would the clutch cable have any effect on the bike drifting right? Just asking to learn ...
Old Feb 14, 2018 | 12:40 PM
  #53
texashillcountry
Dirt don't hurt
I'm gonna say no because you don't have the wheel spinning which provides a gyroscopic force that would counteract the force of the clutch cable.
Not to mention the other forces working on a bike in motion.
Old Feb 14, 2018 | 04:11 PM
  #54
Spanners39's Avatar
Spanners39
All Harleys look like the front end is misaligned from the factory, partly this is due to the bikes not sitting upright when you ride them (this is to do with camber)....follow a few and you'll see what I mean.
It's a mission to get then to look straight because they basically only look straight if you lean to one side as you ride.
Wobbles on corners has very little to do with alignment in the twisted in the trees sense but having the wheel centred in the forks has an effect and so do tyres and all that other frame stuff.
I had a customer kept coming back and trying to get me to improve his handling and to no avail until he admitted, and I quote "It's only that really bumpy left-hander going into Albany, if I slow down when I hit the bumps it gets out of order"
I asked him "Which lane are you in when this happens and how fast?"
He said "75MPH and the left lane with the throttle feathered as I hit the bumps"
I said "Take that corner in the right lane, slow to 60mph just at the end of the straight and power through it on a rising throttle through the corner"
Handling problem fixed...it was the rider, not the bike, as we say in NZ "ride to the conditions" lol!
Old Feb 14, 2018 | 04:28 PM
  #55
texashillcountry
Dirt don't hurt
Yeah we have 2 different conversations going on in this thread.
It's all good.
Who doesn't like a good hijack????????
Old Feb 14, 2018 | 05:53 PM
  #56
Prot's Avatar
Prot
Is it possible the forks are slightly bent in such a way that one is slightly ahead of the other?
Old Feb 14, 2018 | 06:31 PM
  #57
texashillcountry
Dirt don't hurt
No...
Old Feb 18, 2018 | 06:36 PM
  #58
Max Headflow's Avatar
Max Headflow
You might have dented steering bearings in the neck. You get the wobble because the rollers are riding right on the edge of the dent.. Try getting the fron wheel of the ground and snug the bearing up so that they are fairly tight then rotate the forks back and forth. Check that they move smoothly.. If OK do the std bearing adjustment and look elsewhere.
I would also remove the front wheel and fender then try moving the lower part of the leg front to back while someone holds the forks straight.. If play is excessive, rebuild the forks. Heck if you got over 50K on the forks, its worth while to rebuild them with new bushings. Like you said, check the springs too.
Old Feb 18, 2018 | 06:49 PM
  #59
texashillcountry
Dirt don't hurt
Tried that.
I'll try the second after I look at the rear tire.
Like I mentioned before I had to realign the rear wheel but I never got around to looking at the tire itself for damage due to being run for 2.5-3k miles at a slight angle.
Old Feb 18, 2018 | 08:11 PM
  #60
Beemervet's Avatar
Beemervet
Rather than looking for damage, check for uneven wear. That in itself may be causing the bike to "hunt" for the proper track.
