I found that in hard left hand corners I would get a bad wobble. All right hand turns are like riding on a rail. The only time the wobble shows up is in hard left hand turns.
First thing I did was check wheel alignment and it turned out the rear wheel was 3 flats out of adjustment so I fixed that and the wobble got a lot better but still a little bit there.
Wheel bearings are new.
Checked the swing arm and pinch bolts.
There is an equal amount of fluid in both forks.
I'm down to thinking that the left fork spring is a bit weak.
Does that sound right to y'all or am I barking up the wrong tree?
Sounds like you've checked the usual suspects - bearings, etc... You may have a belt separating on one of your tires. Hard to check without cutting the tire open, but try putting bike on a stand and while rotating each wheel, see if you can detect and out of round condition or bump.
