Acceleration problems on a 1990 ultra classic
Old Mar 7, 2018 | 10:12 PM
Crw606's Avatar
Crw606
1st Gear
Default Acceleration problems on a 1990 ultra classic
i just bought a 1990 ultra classic with the 80in evo the guy I bought it from told me that it was running fine then out of nowhere it would Accelerate to a certain rpm and could go over 30mph it idles fine but when you crack the throttle it spits and backfires out the carb where do I need to start to fix this
Old Mar 7, 2018 | 10:17 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Clean the carb.
Old Mar 7, 2018 | 10:21 PM
Crw606's Avatar
Crw606
1st Gear
Originally Posted by texashillcountry
Clean the carb.
the guy said he rebuilt the carb still didn’t fix
Old Mar 7, 2018 | 10:30 PM
TSheff's Avatar
TSheff
I believe THC said clean the carb. It's not a big deal and cheap, so if it doesn't work not a big loss. Throw some new plugs and wires on it while you're at it. Was it rebuilt correctly?? Correct jets or TOO BIG?
I prefer to change to a S&S carb, simple adjustment and done.
Welcome to the Forum. You'll find all kind of people here. When you are asking questions, especially to the EVO, Shovel, or Panhead people, most know a little (a lot) about them or they wouldn't still be riding. People here can walk you through just about anything if you give them enough information and the do what they suggest. Yes I have an 89 FLHTCU.
Old Mar 7, 2018 | 11:00 PM
Crw606's Avatar
Crw606
1st Gear
thanks and i haven’t picked the bike up yet won’t be till Sunday befor I pick it up I’m just trying to figure out where to start when it here and I had some one tell me to put the s&s super e on it but I don’t wanna do that cause I plan on rebuilding it next winter just wanna get the carb thats on it right if I can for this summer this is my first Harley and need to learn about it like what to expect and all and idk if that guy rebuilt the carb right or not I know it’s hard to start but once it’s start it idles fine but crack the throttle and I spits sputters and backfires through the carb
Old Mar 8, 2018 | 07:18 AM
86glider's Avatar
86glider
the s&s is a great starting point for the rebuild,you'll get to ride and enjoy it till you're ready, just my 2 cents.good luck with it!
Old Mar 8, 2018 | 07:21 AM
texashillcountry
Dirt don't hurt
Unless the previous owner is a friend don't trust anything they tell you.
That last part tells me there is a lean condition happening.
1: Make sure the float level is correct
2: Check the rubber connector that the carb goes into to make sure it doesn't have any cracks
3: Check your intake gaskets
Let us know what you find.
Personally I much prefer the E to the stock carb because of how it mounts to the intake (well that's one of many reasons)
Old Mar 8, 2018 | 08:10 AM
Tom84FXST's Avatar
Tom84FXST
The number of people who think they can rebuild a carb...and the number of people who can actually do it... is vastly different.
Old Mar 8, 2018 | 08:34 AM
0maha's Avatar
0maha
Not sure I get what's going on here.
OP, have you actually ridden this bike yet? Sounds like you are saying all of this is based on what the seller told you about how the bike is misbehaving. If so, I wouldn't plan on anything until you have the bike in hand and can see for yourself what's going on.
The S&S is nice, but there's no reason the factory Keihin CV carb won't run just fine.
Old Mar 8, 2018 | 09:18 AM
grbrown's Avatar
grbrown
Exclamation
We're currently working with secondhand info! Tell us more when you own the bike, have it at home and have run it/ridden it and can tell us first hand what is going on.
