transmission drain plug stock ???
Old Mar 18, 2018 | 01:03 PM
evobigape's Avatar
evobigape
Default transmission drain plug stock ???
do you have a trick guys my flstf 1998 drain transmission plug located on the side pipe is stock i cant remove i just broke a allen and just to be sure what is the size of the allen because the guy who have the bike before just strip it a bit
Old Mar 18, 2018 | 07:26 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
It's not an allen it's a torques head bolt.
IIRC it's a T-30.
What can't you remove? The pipes?
Old Mar 18, 2018 | 07:32 PM
WP50's Avatar
WP50
Unless someone changed it THC nailed it Which has happened
WP
Old Mar 18, 2018 | 07:38 PM
texashillcountry
Dirt don't hurt
WP
You mean I already hit my quota for correct answers this year????
Damn it's only March!!!!!!
evobigape's Avatar
evobigape
i remove the pipe to reach the drain plug is more easy but the plug is stuck im gonna try the t30 to see
Old Mar 18, 2018 | 07:40 PM
texashillcountry
Dirt don't hurt
That drain plug is the same as the one used on the primary.
Old Mar 18, 2018 | 07:50 PM
evobigape's Avatar
evobigape
ok so when i drain the primary the transmission drain too ?
Old Mar 18, 2018 | 07:52 PM
texashillcountry
Dirt don't hurt
No!!!!
The drain plug used on the transmission is the same size and type used on the primary...Two different plugs!!!!!
It's just easier to get to the one on the primary to confirm what size torques socket fits it.
Old Mar 18, 2018 | 07:56 PM
evobigape's Avatar
evobigape
ha ok im sorry im gonna try the t30 i have to change my clutch cable thats why i need to drain the transmission
Old Mar 18, 2018 | 08:04 PM
texashillcountry
Dirt don't hurt
You are gonna want some teflon paste to put on the threads of the plug when you put it back to help seal it.
