Diagnosing not start condition
Old Mar 19, 2018 | 06:12 PM
just plain john's Avatar
just plain john
Default Diagnosing not start condition
I'm new to Evo's, and had a situation yesterday where the stator plug was disconnected while riding long enough to drain the battery and leaving me stranded on the side of the road. I got the bike home and got it on the battery tender, and I had a green light on it when I got home from work. It spins over at what sounds like the usual speed but won't start. Can anyone point me to some technical advice regarding diagnostics? I can check the stator easily enough but not the regulator since it won't run.
Old Mar 19, 2018 | 07:13 PM
aces&8s's Avatar
aces&8s
Strange, Don't have an answer.
Old Mar 19, 2018 | 08:05 PM
Racepres's Avatar
Racepres
Not starting is Not due to charging system if it Turns Over..
Pull wires and attach spare plugs [grounded] and check spark!!!
Old Mar 19, 2018 | 08:18 PM
Dr.Hess's Avatar
Dr.Hess
Spark, fuel, timing and compression. You're missing one.
Old Mar 20, 2018 | 06:36 AM
just plain john
Yeah, it ran without issue before this. I suspect spark, but it's just a guess. Not sure how to proceed.
Old Mar 20, 2018 | 06:41 AM
Scudda's Avatar
Scudda
Check for fuel first..it's the easiest thing to check. Next check for spark. If you still have an issue then check compression......Actually the first thing you need to check is for the correct battery voltage then check the list
Old Mar 20, 2018 | 07:49 AM
86glider's Avatar
86glider
pull a plug,spin motor,check for spark
Old Mar 20, 2018 | 08:32 AM
splattttttt's Avatar
splattttttt
not being me mechanically inclined. Especially when it comes to electronics, how is this action performed?
I’m guessing with the plug out and still hooked to ignition wire, start bike and look for spark?
Or does the tip of the spark plug need to be touching a metal spot?
I figure at some point it might come in handy to know.
Thanks!
Old Mar 20, 2018 | 09:27 AM
Mattbastard's Avatar
Mattbastard
Thanks!
Yup, the latter. You hook the spark plug into the plug cap all the way and you touch the threaded part of the spark plug to the cylinder head firmly so you get a good ground. Then hit the starter and watch for a little spark. It helps to be inside a garage or somewhere darker than outside so you can see the spark easily.
I'd wear a leather glove, sometimes the spark can travel through a shitty spark plug boot and give you a little zap. Nothing deadly, just uncomfortable.
It also helps to take both spark plugs out so the motor spins easily.
Old Mar 20, 2018 | 10:51 AM
0maha's Avatar
0maha
I remember learning that one the hard way when I was a kid! I had scrounged up an old lawn mower from a neighbor, and was piddling around with it in the garage. Was actually pretty surprised when I eventually got it started. Had the really nifty idea of reaching down and pulling the wire off the spark plug. An eight year old learns right away not to do that twice!
(It was a different world then, wasn't it! My mother happily left me to my lawn mower and gasoline in the garage. One suspects that today's young mothers are more cautious. Too bad.)
OP, nothing here to really worry about. Personally, I'll put on the gloves, then hold the spark plug with an insulted pair of pliers. Never have had one bite me doing it that way. If you have someone around who can thumb the started for you, that helps. Allows you to get right down there and really look for the spark.
