charging / electrical problem? 86 FLHTC
Old May 6, 2018 | 06:31 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Originally Posted by elmo4fun
ok. if it makes any difference, the guy i bought it from claims he upgraded to a 32amp charging system. not sure i believe him. he also said it was a relatively fresh rebuild and i had to put new head gaskets on last weekend.
FWIW I never trust what a previous owner tells me unless it is a good friend.
Old May 6, 2018 | 07:12 PM
elmo4fun's Avatar
elmo4fun
OK update : went out to recheck everything. looks like im getting about 13 volts at idle about 11-1200rpm and looks like 14 at 2500 rpm. so it all looks good until i turn on the turn signals then all bets are off...lol. im betting my LED conversion later this week will all but fix that.
Old May 6, 2018 | 07:33 PM
texashillcountry
Dirt don't hurt
I gotta ask...are you still looking at the gauge in the dash?????
If you are having problems when you turn on your turn signals then you will still have the problem if you put in LEDs.
Personally I'm thinking a magnet shifted on your rotor assembly or you simply have some very dirty contacts.
It could be several things but without testing you'll never know.
Good luck.
Old May 6, 2018 | 07:37 PM
elmo4fun's Avatar
elmo4fun
was checking with a meter at the batery. but then i dropped it. lol so the turn signal observation is from the dash. all the others are from the meter
Old May 6, 2018 | 08:10 PM
bagga's Avatar
bagga
the harley volt meters on the dash are notorious for being inaccurate. the meter on my 85 is all over the place all the time. i check my voltage with a hand held meter and every time i check it's different than the meter on the dash.
Old May 6, 2018 | 08:24 PM
daven9113's Avatar
daven9113
I think you are fine. I get the same reading on my 89 FL when I turn on the blinkers looking at the voltage meter on the dash, especially at a stop sign. Has not really been an issue. I know I have a good charging system and battery.
bootcampsam
Sep 19, 2016 12:32 PM
knights
Apr 21, 2014 01:24 AM
fxrtfan
EVO
13
Aug 20, 2011 05:31 PM
ScooterJammer
Apr 28, 2008 04:55 PM
bigshooter181
Mar 26, 2007 06:55 AM
