Identifying this Motor
Old May 10, 2018 | 04:30 PM
Chris Sigo's Avatar
Chris Sigo
Default Identifying this Motor
Picked up a project with this motor sitting in the frame. I haven't been able to identify the manufacturer. There are no markings other than the case #"s, and no obvious identifiers. I checked the flywheels and there is only a single line and a single dot for markings.
It is not an early Ultima as I had initially assumed, I called Midwest and verified. All the casting and parts look like it is a complete motor from a maker, not put together from different brands. No marks on the heads or cylinders either.
Thanks for taking a look.
Old May 10, 2018 | 05:14 PM
Tom84FXST's Avatar
Tom84FXST
The cases are STD...as for the rest of it...who knows...everything is polished away.
Old May 10, 2018 | 07:09 PM
uawman's Avatar
uawman
EVO, probably big boar due to lower fins removed and polished
Old May 10, 2018 | 08:35 PM
Chris Sigo's Avatar
Chris Sigo
So is removing the lower fins a common thing to do for big boring?
They could be OEM cylinders then, but shaved and polished?
Thanks
Old May 10, 2018 | 08:37 PM
Chris Sigo's Avatar
Chris Sigo
That they are! Thanks for the quick clarification.
Old May 11, 2018 | 03:39 AM
grbrown's Avatar
grbrown
The cylinder castings don't look as it they have been shaved, more likely, if it is a completey new build, that they were cast like that, then polished. Might be worth doing a search for other STD engines, to see what you can find.
Old May 11, 2018 | 12:58 PM
98hotrodfatboy's Avatar
98hotrodfatboy
I thought stroker motors use those style jugs.. You can measure the stroke through the plug hole or you can pull the heads... Might be advisable to disassemble it to make sure of what you have..
Old May 11, 2018 | 07:11 PM
misfitJason's Avatar
misfitJason
Looks like axtell striker cylinders
krouke
Nov 15, 2018 02:43 PM
cm1101
General Topics/Tech Tips
Nov 2, 2015 11:50 AM
D1gger
Aug 29, 2012 02:20 PM
CSS_FXD
Apr 30, 2011 07:03 PM
Frisian HD
Nov 24, 2007 03:45 PM
