Valve train noise
Old May 28, 2018 | 02:43 PM
user 47363638's Avatar
user 47363638
Default Valve train noise
I just redid my top end with a revolution performance 85” kit with 10.5:1 compression, I also had them do my heads, port and polish, bigger valves and high lift springs, I changed my cam to a Tman590, .590 lift, fueling lifters and S&S pushrods. I am not surprised that it is a little louder with a bigger drive train and it doesn’t sound like it’s coming from any specific location, it’s actually louder when it’s hot, I’m just wondering if it’s normal and how loud is acceptable.
Old May 28, 2018 | 03:38 PM
Kingglide549's Avatar
Kingglide549
Acceptable?
I will allow a tick but not much more.
You need to ID where and what it is, B4 you can say too much about it.
Is it P rods hitting the tubes? (real common)
A bigger cam with proper geometry and good lifters will not make any more noise than a stock cam.
Old May 28, 2018 | 03:49 PM
Yankee Dog's Avatar
Yankee Dog
Don't know the answer but is .590 lift OK without relief of the area around the cam bearing? Just a thought. YD
Old May 28, 2018 | 03:57 PM
TwiZted Biker's Avatar
TwiZted Biker
That cam has a pretty aggressive ramp so I'd be expecting a bit more valve train clatter, you running syn or dino ? Syn, change it and try Spectro 25-60 dino.
Old May 28, 2018 | 04:01 PM
user 47363638
A little grinding had to be done.
Old May 28, 2018 | 04:03 PM
user 47363638
Not the first time I’ve heard that, I’ll try that next oil change.
Old May 28, 2018 | 04:27 PM
Uncle G.'s Avatar
Uncle G.
You're not really doing an Evo any favors running synthetic. they don't need it and they don't like it.
Old May 28, 2018 | 04:56 PM
ROCKOUT Rocker Products
Sponsor
+1 on Spectro 25-60... I've preached it for a long time.
You might also take a look around my website... might be just what you need
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old May 28, 2018 | 05:35 PM
98hotrodfatboy's Avatar
98hotrodfatboy
The T-man cams are similar to the Woods cams... How much preload do you have... Setting to .140" is typical to quiet things down.. post a video, we'll let you know..
Old May 28, 2018 | 06:24 PM
Kingglide549
What is your basis for that fact?
I have since it came out, zero problems.(with oil)
