Why do these bikes sound different?
Give me Dual Fire Everythime thank you... Of Course... If Dual Plugged... SingleFire is the Answer... if Single Plugged... No Answer necessary!!!
Both mild stage1 tuned
Her’s sounds like it idles lower, but no tac, so can’t supply an actual number
Mine idles between 9.5-10.5 and sounds way faster
Her’s will stall in start up iccasionally.
I wanna say the cam on hers may nit be stick, but bought used, si can’t varify
When idling lower than 1000 warmed up, after a short time the vacuum - engaging VOES and keeping the ignition in an advanced state - drops under a certain threshold and opens up VOES, retarding the ignition, causing the drop in RPM. So, I disabled VOES on idle speed.
Using a little and simple to fabricate aluminum bracket together with 2 small spacers and a micro switch from a Ducati front brake I got lying around doing nothing.
On idle it engages the switch disabling VOES
Rolling on the throttle just a tad disengages the switch, enabling VOES
Now, its happily potato-potato'ing at 500 rpm
My pressure gauge tells me there is oil, even about as much as 400 rpm higher. On hot days there is 0 psi, but then there is also 0 psi at 900 rpm. For what oil pressure is worth in a roller bearing engine...
i might be completely wrong but its what a long time mechanic told me way back.
Having been a Shop Owner, in a Fairly small community, where we Know all of the Bike Owners Far and Wide... You will find that the guy who consistently Idles that low, will consistently need a Bottom End when we finally get it in the shop..In fact one Meticulous by the book type guy... has Not had a Bottom End in Many many Miles.. Just Lucky I bet!!
Or, Looks like the guys that "Wrote the Book" might know something after all??
I Idle fairly low these days, just to **** Off the Injected Guys... who Can't... But, I Keep a Bottom End on the Shelf!!! I said already we used to have a Shop!!!
Sound??? I think open pipes on any Harley with aluminum heads sounds like ****... Just Noise. Bigger Diameter resonators/mufflers are a Nicer Tone..
Now Iron Motors, Knucks, IH Sporties... Sound Sweet with "Drags" Shovels are Next with their Iron Jugs.. E-Motors???? Lame... Noisy but Lame!
