IDK, I will look around and see.
The trouble is I was working in a HD shop when the EVO came out and i have a lot of stored info in my brain.
I will see if i can verify it.
Yer Wasting yer Time....
Besides, if everything Recommended in the Book needed to be Defended and Defined... How big ya think that book would be?????
Some people Defend their [mis] beliefs to the Grave even!!! Can't do Nuthin about it..
I have stood down, until I find the proof -if there is any.
It seems like it is written in my hard drive somewhere..
Now i want to know where and why.
Other wise I have to retract the statement .
Car manufacturers used to call U joint failures "brinneling " which came from transport sitting still on trucks.
This of course was referring to new cars with fairly low miles and very early U joint failures
"Brinelling
Brinelling is the permanent indentation of a hard surface. It is named after the Brinell scale of hardness, in which a small ball is pushed against a hard surface at a preset level of force, and the depth and diameter of the mark indicates the Brinell hardness of the surface.More at Wikipedia"
Ah yes, thanks for that. I read it as something we call 'sintering' here, but it turns out sintering is an English word after all We don't have word for Brinelling though
Hey no worries Its just that there are so many different stories about it (all of course with the best intentions), when you brought it up I hoped to finally get it clear as to why the whole world seems to idle as low as possible, while they should not do it because its bad.
Not me
I stand by what I wrote...
Originally Posted by Racepres
Having been a Shop Owner, in a Fairly small community, where we Know all of the Bike Owners Far and Wide... You will find that the guy who consistently Idles that low, will consistently need a Bottom End when we finally get it in the shop..In fact one Meticulous by the book type guy... has Not had a Bottom End in Many many Miles.. Just Lucky I bet!!
Course Shop was only open about 30Years... Didn't see it All....
His idle is turned down to get that potato sound. Probably about 8-900 rpms. Yours is higher, about 1100-1200, where its recommended for charging and oil circulation.
His bike is only charging when hes moving. Sounds good but not good for the engine.
JMO YOMV
The idle on the '98 is lower than 8-900, more like 700, possibly 600. The other bike sounds like it's idling right. My H-D service manual for my '98 FXD Super Glide says to idle at 1050-1100, and the other bike in the videos sounds like it's about right. His carb isn't tuned very well though. There was a severe hesitation on a few of the blips.
Why not? During the rebuild I did I got oil from the rockers when cranking the engine by turning the rear wheel by hand. I got even more when cranking it on the starter which is about 200 rpm. Why would there be no oil at 500 rpm?
My pressure gauge tells me there is oil, even about as much as 400 rpm higher. On hot days there is 0 psi, but then there is also 0 psi at 900 rpm. For what oil pressure is worth in a roller bearing engine...
That lope is hard on the internals like the crank and such. The 1050 rpm that the bike is *supposed* to have makes the flywheel turn fast enough to make the engine turn far more smoothly and easily, whereas the slow idle puts a very hard push and pull on each stroke. Wrist pins, crank, all kinds of stuff won't last too long.
And yes, you are correct about the oil, it's *not* anything to do with it not getting enough oil rotating at 500 rpm's, it'll get plenty of oil at 50 rpm's, but then that would be even harder on the parts alreaqdy mentioned - oiled or not.
When I had my "Sifton" top end, head work, etc., dual fire ignition on my FXR and an S&S Super B my engine sounded just like the first one except I had the idle set a little higher. Definitely the ba da dup - ba da dup - ba da dup potato sound. I also ran straight pipes then too.
Then I installed dual plug heads, single fire ignition, an S&S Shorty E, a slightly milder cam and Pythons with baffles mine now sounds like the second one.
Seriously it was like listening to the two versions of my bike in the vids above.
