Why do these bikes sound different?
Old Jul 23, 2018 | 08:24 AM
98hotrodfatboy's Avatar
98hotrodfatboy
I have heard that a low idle like that causes premature stress on the crank pin instead of the mass rotating smoothly it's banging the crank pin each time it fires which is not good for the crank pin...
Old Jul 23, 2018 | 08:45 AM
Kingglide549's Avatar
Kingglide549
Originally Posted by Daedalus
Why not? During the rebuild I did I got oil from the rockers when cranking the engine by turning the rear wheel by hand. I got even more when cranking it on the starter which is about 200 rpm. Why would there be no oil at 500 rpm?
My pressure gauge tells me there is oil, even about as much as 400 rpm higher. On hot days there is 0 psi, but then there is also 0 psi at 900 rpm. For what oil pressure is worth in a roller bearing engine...
I am just quoting the book.
Do as you wish
Old Jul 23, 2018 | 08:49 AM
Daedalus's Avatar
Daedalus
Which book do you have? Not trying to be thick here, really like to know what is where, cause my book states to keep idle around 1000, but it does not say anything about no oil when going any lower. Or at least not where I am looking
Old Jul 23, 2018 | 09:03 AM
Kingglide549
IDK, I will look around and see.
The trouble is I was working in a HD shop when the EVO came out and i have a lot of stored info in my brain.
I will see if i can verify it.
Old Jul 23, 2018 | 09:15 AM
98hotrodfatboy
So not true...... if hot and idling at 900 rpm with 0 psi your oil light would be on. The switch is designed to come on@3 psi. At 900 rpm an Evo typically has 5-6 psi with 20w-50 dino...
Old Jul 23, 2018 | 09:31 AM
Daedalus's Avatar
Daedalus
Not true? Those are my observations. And I dont have an oil light, thats why I mentioned a gauge.
Thats the oil weight I'm using and thats what my gauge is normally showing me, also at 500 rpm! When it goes over 30 degrees C outside, which it regularly does in the past weeks, it's 0. But again, oil pressure in an engine with open bearings doesn't mean much, so its a non issue anyway.
Old Jul 23, 2018 | 09:45 AM
Racepres's Avatar
Racepres
And, I thought they called it Brinneling... but... I do Not really recall!! No Doubt about it tho... it is Bad for Bottom Ends.
LOL
Yer the Guy that reads the Rule Book and Points out all the **** we didn't tell ya Not to Do!!!!
Do Whatever ya want to... Keep a Bottom end on the Shelf... Thats what I do!!!!
Old Jul 23, 2018 | 09:48 AM
Kingglide549
I hate saying something I can't back up,
so far the only thing I have found is recommended idle of 900 to 1000, but no reasons.
I will search .
Old Jul 23, 2018 | 09:53 AM
Daedalus's Avatar
Daedalus
Brinneling is contact welding. For a crank it means debris getting pressed on to the surface with so much stress it gets welded onto it. Its characteristic for engines with open bearings like Harley engines, but it usually happens under great stress. On idle speeds, the engine is virtually doing nothing
Old Jul 23, 2018 | 09:59 AM
Kingglide549
Brinneling is contact welding. For a crank it means debris getting pressed on to surface with so much stress it gets welded onto it. Its characteristic for engines with open bearings like Harley engines, but it usually happens under great stress. On idle speeds, the engine is virtually doing nothing
Car manufacturers used to call U joint failures "brinneling " which came from transport sitting still on trucks.
This of course was referring to new cars with fairly low miles and very early U joint failures
"Brinelling
Brinelling is the permanent indentation of a hard surface. It is named after the Brinell scale of hardness, in which a small ball is pushed against a hard surface at a preset level of force, and the depth and diameter of the mark indicates the Brinell hardness of the surface.More at Wikipedia"
