FXR brake upgrade - Why won’t this work?
Old Jul 18, 2018 | 02:24 PM
  #41
Mchad's Avatar
Mchad
Went out for a ride and I gotta say, even though they aren't even CLOSE to bedded/broken in, these Lyndall Gold Plus pads are light years ahead of whatever crap came with the Wilwood caliper. I followed some advice from another thread here and did about 10, not aggressive 35mph to almost stops, let them cool down then did 8 45-50mph to almost stops, a bit more aggressively. Made sure not to let the pads sit on the rotor under pressure while not moving. Now I'm supposed to wait 24 hours. I know, over-complicating things as usual.
Anyway, I can't wait to see how these feel as they break in further. So far, a very noticeable improvement. They will definitely go on the right side as well. when I get all the parts together.
Old Jul 18, 2018 | 07:18 PM
  #42
TwiZted Biker's Avatar
TwiZted Biker
You pick the caliper new or used ? Pads came with mine I damn near pulled a stopie first time I grabbed a handful, was not ready for that haul down.
Old Jul 18, 2018 | 08:19 PM
  #43
Mchad's Avatar
Mchad
Got it New. That’s odd. I wasn’t blown away by it. Though it was a dramatic improvement over the single piston stock caliper. I guess my problem is that both my other bikes have dual discs vs the single on my FXR.
Old Jul 23, 2018 | 02:59 PM
  #44
Mchad's Avatar
Mchad
The fork lower just shipped, should be here in a few days, after which it'll get a quick turnaround out to Pau'ls Chroming in PA. While that happens I'm going to start gathering other parts. Looking at this rotor, which is on my current left side. 44101-95A. Looking at the install PDF from HD, it says something I found a bit odd: "This brake disc must be used ONLY with brake pad kit 44063-83C If that brake pad kit is not used, the disc will be damaged and its useful life shortened." So according to this my Lyndall Gold + pads will tear through this rotor?
I'm going to assume this is typical "use only our parts or else" BS, right?
Also, when I remove the wheel to swap the fork lower, do I need to repack the wheel bearings if they've been done within the last <700 miles/2 months?
Thanks
Old Jul 23, 2018 | 06:31 PM
  #45
multihdrdr's Avatar
multihdrdr
Disregard HD Brake Pad statement
Not necessary and you won't be pulling seals
Thanks
Old Jul 23, 2018 | 08:43 PM
  #46
Mchad's Avatar
Mchad
Appreciate it Multi. Do I need to grease the axle? If so, the only grease I have is Moly slide or tetra gun grease for my M1, so what should I get?
Old Jul 23, 2018 | 09:16 PM
  #47
multihdrdr's Avatar
multihdrdr
You don't need much of a "coating" ... No "Build-up" needed ... You probably will still have enough of that "Fresh" grease on it when removed to just rub it around (Re-distribute) on the axle. If not enough, just stick your finger in the grease seal and get a little more. If you had a bunch on it, it would just get scraped off by the inner bearing races when pushing it through.
Old Jul 23, 2018 | 09:22 PM
  #48
Mchad's Avatar
Mchad
Cool, thanks. This will be my first time taking off a wheel. Even thought its technically against the rules of my condo to do this kind of work in the garage, I figure I can get the wheel and right fork off pretty quickly, put a cover over the bike and bring the fork up to my apartment to swap the internals with the new slider (which I was happy to see shipped from Surdyke today) Chrome shop said they'll be done in a couple of weeks, so I am hoping to have this project done before September!
Old Jul 26, 2018 | 03:03 PM
  #49
TwiZted Biker
Shut the door or leave it down with some air space for venting and it's none of their damned business.
Old Jul 26, 2018 | 03:11 PM
  #50
Mchad's Avatar
Mchad
Yeah, no door. Big underground lot with 100 cars. Painted lines on the deck separating cars. No hiding it, and everything is everyone’s business it seems.
DBLJ
Wheels/Tires
Nov 29, 2011 11:25 PM
softail99custom
Mar 22, 2010 01:44 AM
schwangster
EVO
Aug 23, 2008 03:46 PM
DOORZ
Jul 28, 2008 07:21 PM
mrbones
Mar 20, 2008 12:16 PM
