Never ends....does it?
Old Jul 17, 2018 | 02:30 PM
Jasper86's Avatar
Jasper86
Originally Posted by 1997bagger
Painting the tins a pearl/metallic white....but then we'd have TWO big cube white-bikes....and people might not be able to tell us apart lol
They can tell, I have a touch of being nutz, you are full blown nutz
thats only partially true. I never put my engine in a trash can!
PS: the antigravity lithium batteries are NO FREAKIN JOKE....this bikes normally a bastard to start, especially if its been sitting a while. fired up within 2-3revs, and ive honestly never heard/felt it crank faster. kept power/ground to breaker and starter, and doubled up with #2ga cables straight from battery to starter, and wham, she spins like a top. 880 cranking amps is a glorious thing
Old Jul 17, 2018 | 08:39 PM
1997bagger's Avatar
1997bagger
Jasper86;17519164]thats only partially true. I never put my engine in a trash can!
Still not scared of my wife no matter what you guys think, rule my castle.
Old Jul 17, 2018 | 09:22 PM
Beemervet's Avatar
Beemervet
Old Jul 17, 2018 | 09:30 PM
TwiZted Biker's Avatar
TwiZted Biker
Default Never ends....does it?
Brah you have no idea, try having the same shovelhead as a daily/ trip bike for 35 years. I couldn't begin to list the trail of broken stuff I chased over that time and being honest more than a little was self induced.
Old Jul 18, 2018 | 06:00 PM
Beemervet's Avatar
Beemervet
Old Jul 18, 2018 | 06:35 PM
1997bagger's Avatar
1997bagger
Originally Posted by Beemervet
That's the look when they are unloading your big cube Evo off the delivery truck and you know how you can get it past the wife.
Old Jul 19, 2018 | 06:15 PM
Jasper86's Avatar
Jasper86
heh, i can only imagine (not married)
5/16" heavy duty washers, stitched in from the back side (saved as much paint as we could)...fenders too damned thin (wish I had a TIG...not a mig), every strike blew a hole. thinking about JB-Weld to fill in the loose spot on the left side, maybe a little as body filler (i hate bondo, and this oughta be stronger), and then some ghetto spray can action (its mostly behind the plate/lightbar, probably wont see it)
Old Jul 19, 2018 | 07:13 PM
Jasper86's Avatar
Jasper86
JB Weld wins. (I had that in the garage). we'll sand it tomorrow and see how it looks. either way still cheaper than a new fender.
Old Jul 19, 2018 | 09:13 PM
TwiZted Biker
Little tip for mig and thin stuff like that, use a backer block preferably a piece of copper but aluminum will do also in a pinch. Still gets blow through but allows a build up you grind and shape. Bare metal I use solder or wheel weight lead instead of bondo, takes a little practice but much better results that will not peel.
Old Jul 20, 2018 | 07:43 PM
Jasper86's Avatar
Jasper86
no arguements here -- working with what I had, figuring the plan was to HOPEFULLY get it back together before sunday (thats gonna depend on my powdercoater, however)
2 coats of JB weld and some sanding, and sure...you can see it up close...but standing back 2-3 feet, you'd be hard pressed to notice if you didnt know it was there.
first 2 coats of primer are on, gonna try to spray the black tonight, and wetsand a bit to blend old and new. havent planned on clearing it yet, but we'll see how the black dries
