3/4 vs 11/16 master cylinder.
Old Jul 24, 2018 | 07:20 PM
brad75raiders's Avatar
brad75raiders
Default 3/4 vs 11/16 master cylinder.
Which one would be better for dual disc? I have not seen too many 3/4 but it is what I have on my 91 PM controlls. I am contemplating doing the zx14 with dual brembo calipers. What size will work better.
Old Jul 24, 2018 | 07:28 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
The 3/4 will work better.
The bigger the bore the more fluid you push.
The more fluid you push the more pressure you get at the calliper.
The more pressure you get at the caliper the harder the caliper pushes the brake pads into the rotor.
The harder the caliper pushes the brake pads into the rotor the better you stop.
Old Jul 24, 2018 | 07:36 PM
Racepres's Avatar
Racepres
^^^ Yes... But... I'm gonna bet an 11/16 makes enough fluid to more than Fill the Dual Brembo calipers
which means that the Smaller diameter... assuming Caliper Fill [I think we have that] will provide more mechanical Leverage... No More built in Anti-Lock!!
ie Less lever pressure applied, for more Braking action.
Looks like a Situation for Experimentation... Tell us the Result.
Old Jul 25, 2018 | 04:56 AM
grbrown's Avatar
grbrown
The question could be which size does the MoCo use for twin discs! By all means try a small one, but keep the possibility of swapping to a large one in the back pocket!
Old Jul 25, 2018 | 05:33 AM
Kingglide549's Avatar
Kingglide549
The bigger the bore the less pressure you will get with the same amount applied at the lever.
Disk brakes mechanical advantage is less so you need more pressure.
Old Jul 25, 2018 | 06:14 AM
texashillcountry
Dirt don't hurt
Following this logic then a 1/8th inch bore would be wonderful....good luck with that.
Old Jul 25, 2018 | 06:17 AM
Kingglide549
You would get a lot of pressure but not much volume.
It is not logical to argue with the numbers.
Old Jul 25, 2018 | 06:35 AM
texashillcountry
Dirt don't hurt
Using numbers is how you figure out what you need to do the job you want to do (in this case how much pressure you need in the caliper to make the brake pads push against the rotor effectively).
The simple fact is that a smaller bore MC will give you less pressure in the caliper using the same lever distance than a larger bore MC.
Old Jul 25, 2018 | 06:56 AM
Racepres's Avatar
Racepres
You guys are arguing with yourselves.. ie Both correct... but, not talking the same language..
The Distance traveled is a Good Argument... and of course, a Larger Cubic Inch will travel less to make the Given Volume..
Like I said tho... Larger Cubic inch [centimeters if you wish] require More Lever Pressure in order to Create the Same PSI [Pressure] on the Calipers...
So Yea... a 1/8" diameter MC can build Tremendous Pressure with a relatively small amount of Lever Pressure... But, If it is Not enough Volume to move the "Puck" the Required Distance... it ain't gonna Make any... Nothing to Push against...
Fill and Move the Caliper/Puck first... apply PSI second..
Matched system should put the Lever near the End of it's Travel at Lock-up...
Old Jul 25, 2018 | 09:11 AM
texashillcountry
Dirt don't hurt
I have never seen or heard of any braking system that works that way.
Y'all can say what y'all want but a smaller MC will produce less braking force than a larger one.
And that is what the subject of this discussion is about...
