Thinkin' about a Super E
Old Aug 15, 2018 | 10:09 AM
0maha's Avatar
0maha
I put an S&S E on my bobber, just because I wanted the teardrop air filter cover. I don't have enough experience with different carbs to really form an opinion, but the S&S feels far snappier to me than the stock CV carb. The apparent snappiness is almost certainly also related to the fact that the completed bike is about 130 pounds lighter than the stock bike I started with.
Old Aug 15, 2018 | 12:17 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Nope...
I experienced the same when I put a Super E on both of my softails.
Old Aug 15, 2018 | 05:48 PM
user 47363638's Avatar
user 47363638
I have a super e, I like it, after a while, you will be able to figure it out and dial it in for maximum efficiency, mine is the older model.
Old Aug 15, 2018 | 06:40 PM
Hey Man's Avatar
Hey Man
S&S makes great carbs. I've run Super B's and E's for many, many years.
Old Aug 15, 2018 | 08:45 PM
Tony_N's Avatar
Tony_N
Can you use a big sucker and stock air cleaner cover with the S&S Super E or do you have to use the tear drop?
Old Aug 16, 2018 | 10:46 AM
grbrown's Avatar
grbrown
Been happy with my Super G, but then I haven't had to play with it. There is an oddity in that my S&S 107" engine came with a G, whereas the successor 111" comes with an E. Both engines give similar wide torque curves and performance numbers. When newly run in mine gave 107HP.
Old Aug 16, 2018 | 10:51 AM
texashillcountry
Dirt don't hurt
The reason for the change was the E gives a better response at the bottom and mid range and the G is better at WOT.
Since most people don't spend a lot of time at WOT S&S switched to the E.
Above was told to me by the S&S tech I spoke to when I asked him why the change.
Old Aug 16, 2018 | 03:35 PM
Daedalus's Avatar
Daedalus
Thought I read somewhere the Super E isn't very adaptive when it comes to atmospheric changes. Meaning basically it'll start running rich when driving in mountain areas, or lean on sea level, depending on where it is tuned to. Not sure if this is the case though, I don't have one (nor do we have mountains in the Netherlands )
Old Aug 16, 2018 | 05:38 PM
Mattbastard's Avatar
Mattbastard
That is true, but also true with the HSR. CV is less afflicted on account of the slide only going up based on the flow of air going into the venturi, which does not correlate directly with the butterfly/slide carbs because air that's less dense due to altitude inherently will have less volume, therefore lift the slide less per a given throttle position.
It also doesn't bother me.
Old Aug 16, 2018 | 06:29 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Plain and simple what does your pump flow@10"hg... @ .100", .200", .300", .400", .500" and .600" lift? Once you figure that out then put on a carb that can match the flow rate of the need..
