Cold vs. Hot compression numbers.
Old Sep 22, 2018 | 11:32 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Then why did you state "The spark plug on the rear cylinder is loading up, very black and a bit oily"?
Autozone has a leak down tester you can rent.. at 98k miles it might be time to rering... Leak down will tell you.. and then there's the whole "while your at it" a valve job and shave the heads a little too bump the compression to get a little more out of it without going overboard..
Old Sep 22, 2018 | 11:38 AM
Kingglide549's Avatar
Kingglide549
Signed off
Old Sep 22, 2018 | 11:39 AM
GOGOBECK's Avatar
GOGOBECK
The spark plug in the rear cylinder IS loading up... it’s a new condition, it just started after the carb kit and intake seals install. Prior to that they were both a bit sooty, but dry.
Thanks for the info on renting a leak down tester!!!
Old Sep 22, 2018 | 12:31 PM
Prot's Avatar
Prot
Then the one thing that changed is the intake seals. The leaner cylinder has a leak at the intake.
Old Sep 22, 2018 | 12:56 PM
bad tappets's Avatar
bad tappets
Decreased compression from warm to cold can be due to warm oil being thinner and having less sealing properties than thick cold oil. 10% difference cold to warm on a motor nearly 100k, isn’t that much to be concerned about. Also if your valve guides are dripping oil when sitting, that oil can help seal worn rings a bit.
Old Sep 22, 2018 | 02:59 PM
GOGOBECK's Avatar
GOGOBECK
I was thinking the same, I’ll check that again.
Wouldn't an intake leak anywhere lead to both cylinders being leaned out?
Thanks for that explanation. The cold test was in a basement at 70 degrees and hadn’t been started in 6 days, the warm engine was in 85 degree air temps and after a 20 mile putt.
Old Sep 22, 2018 | 05:23 PM
RLH3175's Avatar
RLH3175
I have a 1996 ultra classic FI with 96000 on the bike with pistons and cam changed 2 years ago to wisco 10 to 1, ev27 cam, after reading this thread I decided to do a compression test. I ran the engine for about a minute then pulled the plugs, held the throttle open, rear was 180 psi the front was half way between 175 and 180, so 177. was going to get it to operating temp, but it hasn't stopped raining.
user 47363638
EVO
17
Jul 10, 2018 12:20 PM
Rickierockit92
Shovelhead
Jun 5, 2018 08:27 PM
duelingskulls
Jun 11, 2009 03:22 PM
alaskajeff
EVO
May 1, 2009 07:08 AM
