Clutch
Old Oct 22, 2018 | 12:31 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Originally Posted by texashillcountry
That depends on a properly adjusted clutch.
I have a friend that had new clutch plates go out after 8 miles...
I had to go over to his house and show him how to adjust his clutch.
He obviously didn't have a FSM..... Did he....
Old Oct 22, 2018 | 12:48 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Actually he did.
I gave him one a couple years ago.
Old Oct 22, 2018 | 03:09 PM
grbrown's Avatar
grbrown
Wink
I have friends in the bike trade who tell me that clutch wear differs greatly amongst owners. Some can wear them out in what seems very little time, while others seem to hardly use them at all. We're told the plates are on the limit of thinness, so a PO might have been a drag artist - or something.....
Old Oct 22, 2018 | 03:14 PM
98hotrodfatboy
.005" is more than you think.....
Old Oct 22, 2018 | 03:18 PM
grbrown's Avatar
grbrown
Cool
Agreed, except it is .0025 each side! Not sure off hand how thick they are when new.
Old Oct 22, 2018 | 08:04 PM
Jag Jim's Avatar
Jag Jim
98hotrodfatboy, not sure how to take the measurement you speak of. The clutch is apart at the moment.
Old Oct 22, 2018 | 11:09 PM
98hotrodfatboy
Here is an example of how to measure the amount of movement at the clutch release plate with a dial indicator. This is not the stock clutch (Baker SBD - belt drive) but the method is the same....
Old Oct 23, 2018 | 10:54 AM
1993FXSTS's Avatar
1993FXSTS
I found out the hard way on my 1993 Springer that when the FSM says to use the Harley tool to press the diaphragm spring down to install the outer snap ring, spend the money and use it! I used a home-made ring with my shop press and now neutral can rarely be found with it running. It was always easy before. All I did was take it apart, inspect it and put it back together while I was rebuilding the trans. Eventually I'll buy a new diaphragm and plates, and the tool! THE FSM said the plate would not center properly and neutral would be tough to get with it running without the Harley tool. They were right...........
Old Oct 23, 2018 | 12:02 PM
98hotrodfatboy
2 totally different clutch setups... Your style ended in 97...
Doctajoness
Apr 24, 2017 05:01 PM
Big Dave
EVO
46
Apr 6, 2015 09:11 AM
Butts05Train
Jun 26, 2014 08:22 AM
cdsgunn
Aug 20, 2009 11:36 AM
old skool1983
Apr 17, 2009 02:31 PM
