Shifter fork shaft
Old Jan 1, 2019 | 06:23 PM
PleaseHelp's Avatar
PleaseHelp
6th Gear
Default Shifter fork shaft
Hi 99FXDL. Is it possible to remove shifter fork shaft from right side tranny door instead of removing complete primary?
Old Jan 2, 2019 | 05:44 AM
nibroc's Avatar
nibroc
I don't think so
Old Jan 8, 2019 | 08:10 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Please clarify, do you really mean the shift fork shaft, or are you trying to remove the shifter pawl shaft?
Old Jan 8, 2019 | 10:42 AM
98hotrodfatboy's Avatar
98hotrodfatboy
I'm glad someone finally asked cause to answer his question the way it is written would be "you have to remove the trap door to remove the shaft for the shift fork"...
Old Jan 9, 2019 | 08:08 AM
Dan89FLSTC's Avatar
Dan89FLSTC
You do not need to remove the trap door in order to remove the shaft for the shift forks, you only need to remove the outer right side transmission cover, top cover and shift drum. However... if you are attempting to remove the shifter pawl shaft, you must remove the gearset from the right side of transmission.
Old Jan 9, 2019 | 09:02 AM
98hotrodfatboy
Thanks Dan, it's been a while since I did any trans work.. you are correct.
PleaseHelp
Dec 26, 2018 01:50 AM
marktruckee
EVO
Mar 16, 2013 03:17 AM
jesco
Jul 15, 2011 04:54 AM
dogsong_1013
May 17, 2009 03:21 PM
Sir_folgers
Apr 28, 2009 06:26 AM
