shifter fork installation, 1990 FXRS
Old Mar 13, 2013 | 11:25 PM
marktruckee's Avatar
marktruckee
Default shifter fork installation, 1990 FXRS
I can't get the #3 shifter fork (for 3rd and 5th gears) to sit into it's slot on the mainshaft. I know I'm installing the shifter forks in the right order, as I took a photo before removing them.
For kicks, I tried to install the #1 shifter fork where the #3 should go. It slid into place just fine. #1 and #2 shifter forks slide into their proper spots onto the mainshaft and countershaft
The #3 shifter fors does not appear to be bent and the tips are well within tolerances.
What the heck am I overlooking? Been at for over an hour and I'm about ready to grab a hammer.
Old Mar 14, 2013 | 01:51 AM
Spanners39's Avatar
Spanners39
When you say it won't go in....what is happening? the fork won't fit into the slot ot you can't get the rod in afterwards? Does #3 fit anywhere else?
Old Mar 14, 2013 | 09:10 AM
marktruckee
Fork won't fit into it's correct slot. It will fit into the other two slots. In fact, if I install forks in reverse order, the rod easily slides into place.
Old Mar 14, 2013 | 09:46 AM
marktruckee
Spanner, let me add some more details. Here's what occurred to get me at the point today:
1) removed shifter cam
2) removed shifter forks and rod.
3) removed trap door with mainshaft and countershaft
4) removed main gear and main bearing.
5) installed new main bearing
6) pressed new needle bearings into main gear
7) pressed main bearing into main bearing
8) inspected and installed trap door with mainshaft and countershaft
Everything fell into place. All shafts and gears spin freely. It's the #3 shifter fork that won't fit into it's proper slot, but it easily falls into the other two slots. The #2 and #1 shifter forks will both fit into the slot where the #3 fork is supposed to be.
Thinking about sliding trap door out, placing the #3 fork into it's proper slot and then sliding the trap door back into place. But I'm wondering if I'm just hiding a problem. Could I have made an error in steps 1 thru 8 above that is causing this? I really appreciate your help. Thanks for the quick response.
Old Mar 14, 2013 | 07:16 PM
Spanners39's Avatar
Spanners39
Hmmm, was it in the right place to start with?
Here's what I would do.
With the selector drum to hand I would put the forks in whatever order they work and still sit in the selector drum grooves.
Then I would (with the top off the gear box) make sure it changes gears OK.
If it does then fine, leave it like that but if not, if that fork has to go in that slot I would get in there with a powerful torch and see what the go is.....the only things that will stop it going in are misalignment (bent or wrong fork) and damage to the fork that makes the end too fat.
Best I can do right now.
Old Mar 15, 2013 | 09:58 PM
marktruckee
Good suggestion that led me to the problem.
Removed trap door and main/counter shafts. Installed shifter forks and drum on bench. Things became very clear.
The second gear on the mainshaft was installed backwards. This didn't allow the #3 shifter fork to fall into it's slot, nor slide to the right far enough to fit into the drum. Slid the second gear off, spun it around and everything fell into place.
Please don't make fun of me behind my back - I deserve it publicly. :-)
Thanks again for pointing me in right direction.
Old Mar 16, 2013 | 03:17 AM
Spanners39's Avatar
Spanners39
Aha! You didn't mention you had pulled the gears off the shafts but good on ya for persevering and finding the problem :-)
PleaseHelp
EVO
Jan 9, 2019 09:02 AM
PleaseHelp
Dec 26, 2018 01:50 AM
thibbledorf
Mar 21, 2017 07:46 AM
jesco
Jul 15, 2011 04:54 AM
dogsong_1013
May 17, 2009 03:21 PM
