Bike running rich
Old Jan 6, 2019 | 08:19 AM
Superduper's Avatar
Superduper
Originally Posted by Yankee Dog
I agree with others, gotta find out what your current carb set up is, then go from there. Like THC asked, why did you remove the old one?
Is the current carb clean or something that has been sitting on a shelf for a while? If a stocker, then you probably looking at a 42 slow and around a 170 main.
Where did you get the carb from? Friend? Ebay? etc. Carb could have been taken apart, jets, changed, needle jet (not the needle but the NEEDLE JET) missing or installed upside down, dirty carb, jets, missing slow screw O-ring, hole in diaphragm, mis-adjusted float, etc.
Time to play detective and get a few baseline things determined. YD
i agree with you, I’m gonna find the baseline then go fron there. Thought I should ask here about other things I should check before I go on adjusting carb.
Carb came from a bike with 5000 miles on it. Seemed pretty clean. No broken parts or anything.
To answer all of you on why I changed the carb out. I just prefer the CV. It’s a good carb! Have had them in all my bikes over the years, and no hassle, just this one. I do lots of riding in the mountains, which it can compensate for. S&S not so much. Better milage will also be a good bonus. My old S&S needed a good cleaning and rebuild, so I thought I could switch to something I knew worked for me in the past.
Old Jan 6, 2019 | 09:38 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
That right there is the most important thing.
I'll bet once you re-jet the carb for the smaller motor you will be fine.
Old Jan 6, 2019 | 01:35 PM
WP50's Avatar
WP50
Originally Posted by 0maha
Obviously because he knew how much it would bug you!!
And I bet it did more that THC would admit.
OP A well tuned CV can be a very good thing.
WP
Old Jan 8, 2019 | 08:03 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
The first thing you need to do is disassemble the carburetor and clean it.
You may be running rich because fuel is overfilling the bowl due to debris preventing the needle closing against the seat.
If that carburetor was running correctly on a stock bike previously, then jetting is not the issue.
Old Jan 8, 2019 | 08:47 AM
Schex's Avatar
Schex
Could also be as simple as a plugged air jet (also called air bleed) orifice, you have to check every circuit in the carb, fuel and air.
Also make sure the enricher(choke) is sealing, with the enricher cable installed and closed, spray brake clean with a straw into the starter jet, look for leakage at the enricher drilling,
Old Jan 8, 2019 | 09:03 AM
Mattbastard's Avatar
Mattbastard
You're correct, the CV40 is an outstanding carb, when tuned properly.
You need to dive into that CV and see what you're working with. I'd recommend as a starting point:
3 turns out on the idle mixture screw
45 pilot
190 main
a single #4 brass washer under the needle (raise the needle)
drill slide hole out to 7/64"
That all should get you into the ballpark.
Tat2carson
Carburetor Related
Jun 9, 2019 06:14 PM
cike
Exhaust System Topics
Aug 26, 2012 10:42 AM
hog85
Aug 27, 2011 04:58 PM
JaredHDUT
May 5, 2009 08:38 PM
Rat bike
Ironhead
May 24, 2008 12:29 PM
