Breathers
Old Feb 5, 2019 | 10:54 PM
Racepres's Avatar
Racepres
Originally Posted by Bingee
On a bottom breather you can eliminate most "oil" problems by rerouting the breather hose away from the air cleaner. Use a catch can or just toward the ground. Then make sure the ball check valve in the oil pump is clean and seals well.
Ignoring the fact that an Evacuation system is best... No?
Why Not keep yer **** tuned and in good order, while using the induction system to help with evacuation??? or ... is evacuation not necessary??
I don't but... it may be best!!!
Let's face it... an oil "problem" is in fact a "problem"... should be Fixed...Maybe?
Old Feb 6, 2019 | 04:53 AM
Kingglide549's Avatar
Kingglide549
A "Dry" Sump System works really well if designed correctly..-if- is the word.
We have to remember this is a very old engine design and has worked.
It worked when it was a small cube and lower HP.
It has been made to work for a century.
TYhe EPA mandated their BS about the draft tube and PCV valves back in the late 1960s and this mandate has crept
even to the MC engines, as the idle hands of bureaucracy needs to prove they are doing something ..even if it is retardedly stupid.
The "dry sump systems work well in aircraft, sports cars like the big Porsche engines, and lots of others.
It always provides positive oil Pressure under most circumstances..
Bottom line is HD could have done better, but they chose the antiquated archaic way of doing it.
Old Feb 6, 2019 | 07:44 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
The EPA mandated their BS about the draft tube and PCV valves back in the late 1960s and this mandate has crept
I don't think truer words have ever been written!!!!
Old Feb 6, 2019 | 08:02 AM
Racepres's Avatar
Racepres
All too true... but... has no bearing on the "How To" make what we're stuck with work optimally..
Old Feb 6, 2019 | 10:19 AM
Kingglide549
Sure it does-
Don't try to make gravity do what it does not want to do.
Whilst the original design was to use the pressure from the pistons to help with scavage and lubrication,
it was not ever in their vision to attempt to make AOS system out of it.
Revert to timed bottom breathing and all will be fine.
That is "was" how it worked.
To change that one will have to fit suction line into the bottom of the crankcase and build a propper scavenge pump.
This a 911 pump below, there are many variations with the same theme.
Porsche runs a real dry sump system.
HD could.....they would pick up some real engineers.
Notice the scavage is two-time larger than the pressure side.
How big is it?
More then a large hand full -you can't wrap your finger around it.
The pump not counting the tube depending on which one (many variations as said) is 5 inches to 10 inches long .'
It's very real
Old Feb 6, 2019 | 10:33 AM
Racepres's Avatar
Racepres
^^ That is my point... but, unnecessary if an evacuation pump... even electric is used... or.. Simple thought... use the intake to help in this regard... ala the MoCo method...
Oh Yea... darnnit gonna get oil into the combustion chamber.... Only if something is Not Right anyway!!!!
Especially with a head breather....
BTW There are an abundance of oil pumps out there with Much larger scavenge side than feed, specifically designed for Harley's!!... and we even restrict oil Severely on the feed side..to the point of bypassing up to Half of it... Sometimes Racers are able to provide real World Solutions to Engineering Problems...that apply to All, without re-engineering/ adapting, a 911 pump...for instance...
Old Feb 6, 2019 | 10:38 AM
Kingglide549
I guess we have to give HD an atta-boy for one of the first in "dry sump" attempts.
The trouble with HD is, - once it is gooder enough it stays that way for centuries.
Old Feb 6, 2019 | 11:03 AM
Racepres's Avatar
Racepres
Centuries... LOL ... at Minimum...
BTW I like the Dry Sump, as I do not wish for an Oil supply under my engine... Mostly due to the need to then Raise the bike to clear from Harms Way...
The old 4-speed is King of low center of Gravity... The last true Girl's bike IMO... and of course vertically challenged individuals... And... those of us raised on them...
Old Feb 6, 2019 | 11:49 AM
Kingglide549
The opposite of the spectrum, the old Iron head ---Falling over at a stop on that is incredibly EZ
Old Feb 6, 2019 | 12:04 PM
Racepres's Avatar
Racepres
Yes... exactly.. the old timers Girls Bike... the top heaviest in the lineup...ever, and Guaranteed to make yer pan or shovel look and act Sslllooooowwwwwww!!!
Back in the day, at the Track, the Shovel guys would Cry sumpin terrible if they had to race against Ironheads... The ones that ever did it before anyway!!!
The dawn of the EVO leveled that a bit...and the Twin Cam is Exceeding even that... Slowly...
BTW Speaking of breathing, and Oil Pumps... The Post '77 Sportster cured alot of that stuff rather handily... Took a while to figure out the Breathing part... but Sporty got it right Long before the Big Twins!!!
