Evo rocker box misalignment
Old Mar 26, 2019 | 07:40 PM
Schex's Avatar
Schex
Anyone remember this?
The funny part is I think it actually worked for him.
Old Mar 26, 2019 | 08:06 PM
0maha's Avatar
0maha
https://www.youtube.com/watch?v=ZykR3yqQjqE
That's hard core.
Old Mar 26, 2019 | 08:52 PM
t150vej's Avatar
t150vej
Originally Posted by Harleypilot63
Any experience with this issue out there?
Seen this many times, actually. And sometimes they'll run for years aligned then do it, sometimes right after install. MoCo sent out a notice circa 1991 that the issue would not be covered by warranty so long as they weren't leaking oil, so yeah, some new bikes had it happen from the factory.
Occasionally, you can loosen all the screws, align and carefully tighten them back keeping them straight as you go, but often as not, you get into problems with the fiber washers under the screws leaking afterwards so it's best to take them off, wash the parts (including the gaskets) in warm dishwater, rinse and thoroughly dry everything before you go back and replace whatever you got under the screws. Of course lay the covers/spacers on something flat to make sure they aren't warped and the gaskets aren't compromised. Just be patient and take your time - run 'em down till they touch then about 1/2 - 3/4 turn each alternating in a cross pattern until snug.
Do yourself a BIG favor and use these type washers on the screws if you take them out: They're called sealing washers and they will not leak or get loose. OEM part # 6589. James Gaskets use the same part number and they'll work but aren't the same quality.
Old Mar 27, 2019 | 12:58 PM
ZachE's Avatar
ZachE
That video is awesome, proof sometimes a bigger hammer works for small adjustments. grin.
Old Mar 27, 2019 | 03:04 PM
megawatt's Avatar
megawatt
+1
The worst part of an Evo engine is the rocker boxes, specifically the center piece...stupid design.
I think there was an issue on some `89 year bikes where these parts were made from crappy material, the set on my Softail got so bad that when i snugged down the top covers, I could see inside the rocker area...
I don`t think they will move once everything is torqued down.
Anybody ever try the S&S two piece rocker boxes?
Yeah, I have an S&S engine and the two piece rocker boxes are an improvement over the HD originals, in my opinion.
What I don't like about the S&S boxes is the chrome.
I am not a fan of chrome on aluminum.
Old Mar 27, 2019 | 06:19 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Why do you think it worked, he never reported any results on the video, or answered any of the inquiries?
Old Mar 27, 2019 | 07:17 PM
Schex's Avatar
Schex
https://www.hdforums.com/forum/evo-c...leak-help.html
Old Mar 29, 2019 | 08:57 AM
Uncle G.'s Avatar
Uncle G.
Originally Posted by Rt13MFer
'89 EVO. Could not get the rocker boxes to stop leaking. Replaced gaskets a few times, no dice. Then I honed the gasket mating surfaces of the rocker boxes flat on a 1' square piece of glass from the hardware store with some fine sandpaper taped to the glass. It took a bit of work but I have been 100% leak free for about 5 years now and cost less than $20.
Another source is the stone tiles they sell at Lowe's or Home Depot. They're 1/2" thick marble or granite, 12" square and polished to a perfectly flat mirror finish. I've used a couple of these for all kinds of jobs whether fitting a bridge saddle to a guitar or leveling mating surfaces. Everyone should have one.
Old Mar 29, 2019 | 09:39 AM
0maha's Avatar
0maha
Another source is your local granite countertop fabricator. They just throw their sink cutouts into the trash, and are happy to give you one.
Old Mar 30, 2019 | 07:19 AM
splattttttt's Avatar
splattttttt
Not familiar with how these center rocker frames feel. But based off the video, it’s plain to see and understant why the MoCo originally designed them thattaway. Most as a gasked like application, with no squish ability. So it suffices me to conclude that proper alignement is crucial.
My final thought on them as far as their intended ourpose goes is... WHY?
So glad they abandoned them
