Evo rocker box misalignment
Old Mar 25, 2019 | 07:39 PM
Harleypilot63's Avatar
Harleypilot63
2nd Gear
Default Evo rocker box misalignment
Had a top end done on my evo last year and it runs well. I was washing my bike the other day, however, and noticed that the rear cylinder middle rocker arm cover was misaligned with the upper and lower covers. Pretty significantly, too. They were also misaligned on the front cylinder, just not as much.
I asked the mechanic about it and he said it can’t move once it’s bolted in place. I did not think that was the case, based on what I’ve seen and heard, but he should know (right?).
Question is, can the middle cover migrate out of alignment with the other two? It’s held with just a pinch fit between the upper and lower covers, I believe. The mech implied it must have been that way since the top end but I’m sure I would have noticed it when washing it in the past. Either way, it’s not right in my book and should be corrected before they start leaking.
Any experience with this issue out there?
Old Mar 25, 2019 | 08:27 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
I've never had mine shift after bolting them down.
Old Mar 25, 2019 | 08:52 PM
Racepres's Avatar
Racepres
Me either...
It takes a bit of finesse to get them aligned well..and if yer guy is on flat rate.... well... it takes extra time..
If he used the Good Gaskets... you can loosen and align if it bothers ya.
Old Mar 26, 2019 | 10:48 AM
Hackd's Avatar
Hackd
If it bothers you, than you need to fix it. If it's not leaking, you might be better off leaving it alone. However, the middle box is the one that's prone to warping. I probably wouldn't take the chance on it being mis-aligned, because once it's warped, you're going to need a new one. Oh, and only use the Genuine MoCo stuff. The DS or CC stuff is junk. I have a sad (and long) story about leaking rocker boxes....
Old Mar 26, 2019 | 11:05 AM
Uncle G.'s Avatar
Uncle G.
Yes, the middle rocker cover can be misaligned. There’s nothing to positively locate the middle piece and it’s easy for it to slide sideways when tightening the screws if you’re not paying attention.
When end I put my rocker boxes together, I use a few dabs of Hylomar on the gaskets then assemble the boxes just snug. Then I let the sealant set for a couple of hours before final torque. That tends to keep everything from moving.
Old Mar 26, 2019 | 11:20 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
+1
The worst part of an Evo engine is the rocker boxes, specifically the center piece...stupid design.
I think there was an issue on some `89 year bikes where these parts were made from crappy material, the set on my Softail got so bad that when i snugged down the top covers, I could see inside the rocker area...
I don`t think they will move once everything is torqued down.
Anybody ever try the S&S two piece rocker boxes?
Racepres's Avatar
Racepres
Good thing you ain't on flat rate... But... ya see what I mean!!
Old Mar 26, 2019 | 11:26 AM
Uncle G.'s Avatar
Uncle G.
That’s why I do most of my own work. I’ll take the time to get it right. Besides most “flat rate” mechanics won’t touch a bike this old.
Old Mar 26, 2019 | 11:51 AM
0maha's Avatar
0maha
I've never had them move after being bolted down tight, and getting them aligned isn't hard. Get the four bolts just snug, then get everything perfectly aligned, then apply final torque to the bolts.
Old Mar 26, 2019 | 01:44 PM
Rt13MFer's Avatar
Rt13MFer
'89 EVO. Could not get the rocker boxes to stop leaking. Replaced gaskets a few times, no dice. Then I honed the gasket mating surfaces of the rocker boxes flat on a 1' square piece of glass from the hardware store with some fine sandpaper taped to the glass. It took a bit of work but I have been 100% leak free for about 5 years now and cost less than $20.
