Does anyone one you part number ? This has the starter soliniod mounted on outside of it ,it was last year for that.... Also where can I get one/
THANKS JURGIE
THANKS JURGIE
That's gonna be a tough one, 87 & 88 were stand alone oddball years, find one it's gonna expensive if they know what they have. PM johnjzjz and ask, if anybody has a line on one it would be him.
OEM part # is 60630-86A
What's the issue with yours or do have one ?
Its the shitz one of the cast threads broke on the inner primary 1/2 is still left so when i put the bolt in it has no place for the primary cover to land on for a tight seal it leaks some. Thinking about machining a spacer and cleaning up busted piece then when i tighten it up the cover makes good contact. thanks jeff
If you have machine shop access why not have someone build it up with TIG wire then you can machine it back to stock? It should be cheaper than another primary since you're doing the machining. Weldors appreciate machine shop favors just like machinists appreciate welding favors so you might end up spending no $$.
