How much air in front forks
Old Apr 14, 2019 | 12:38 PM
sB43's Avatar
sB43
Default How much air in front forks
87 FLHTC checked it and it was 0. Can't find it in the manual.
Old Apr 14, 2019 | 05:49 PM
rizzo's Avatar
rizzo
https://www.hdforums.com/forum/touri...psi-level.html
Old Apr 14, 2019 | 06:04 PM
86glider's Avatar
86glider
I keep my 86 at 5-10 psi. You may also want to replace the fork oil if it's been a while.There's a great thread here by Dr. Hess to explain an easy way to do it.Just did mine today.
Old Apr 15, 2019 | 04:35 AM
t150vej's Avatar
t150vej
I run 12 - 15 front, 0 - 5 rear in an '87.
Before you change the fork oil, pump them up and see if they stay up for a couple weeks. Mine had an air leak that got worse over the years and I finally had to pull the dash, replace the o-rings on the fork caps. They make an aftermarket kit with those o-rings, banjo bolt seals, etc.
Also, (my opinion) avoid high performance heavy weight fork oil. I used 20W once and took it out after one afternoon of riding. The correct oil is HD fork oil Type "E" for yours. You won't believe how much better the ride/handling with fresh fork oil, especially if it's been a while since it was changed.
If you don't find the other thread - remove the schrader valve from the crash bar, connect vacuum from a hand or electric pump or a hose from a running vehicle and with a another hose in the oil bottle, suck the oil in thru the drain holes (one at a time). Only takes a few minutes to change it that way.
Old Apr 15, 2019 | 05:43 PM
14GuineaPig's Avatar
14GuineaPig
1987 Owners Manual
https://serviceinfo.harley-davidson....ght%3D99466-87
Dr.Hess
EVO
14
Mar 27, 2020 11:51 AM
rhallman
2014-2024 Touring Models
20
Aug 18, 2016 03:20 PM
WP50
EVO
13
Oct 18, 2011 12:26 PM
Shekinah5678
Feb 23, 2010 06:49 AM
earthdog
Sep 21, 2007 02:44 PM
