Front Brakes
Old Apr 29, 2019 | 01:43 PM
wombat457's Avatar
wombat457
Default Front Brakes
A couple of years ago I decided to upgrade the front brakes on my 97 softail and bought a "Floating Rotor" (thinking about reverting to a "standard type rotor due to noise) together with a Dual Piston Caliper that was "suppose to be" a simple direct bolt on replacement for the oem caliper - it wasn't!
So, can someone recommend a good dual piston (or better) direct bolt on replacement, no extra's/adapters needed, for the oem front caliper (single rotor/disc) please? Also, I bought braided lines as well but gave them away when the caliper didn't fit without adapters and other crap. So am also looking for top quality brake lines as well.
Old Apr 30, 2019 | 07:25 AM
Hackd's Avatar
Hackd
Russell brake lines.
Front brake upgrade: Depends on what your budget it.
Performance Machine if you've got the money: https://www.performancemachine.com/m...-calipers.aspx
Wilwood has a set of calipers designed for HD: https://www.wilwood.com/Calipers/Cal...ppl=Motorcycle
Old Apr 30, 2019 | 10:52 AM
wombat457's Avatar
wombat457
Thanks Hackd and have heard good things about Wilwood Brakes so will give them a try. I see they have a direct bolt on 4 piston caliper as well, that'd be a bonus I think. Also like the look of those Russel Lines as well. Thanks for the links mate.
Old Apr 30, 2019 | 11:33 AM
rivercityslim's Avatar
rivercityslim
Originally Posted by wombat457
Wilwood Brakes have a direct bolt on 4 piston caliper as well, Also like the look of those Russel Lines.
I got the Wilwood calipers, along with their rotors and Russell braided lines. Big improvement over stock. Plus they look good.
Old Apr 30, 2019 | 11:34 AM
LQQK_OUT's Avatar
LQQK_OUT
Good kit! Buy once, cry once.
Z
Oct 31, 2021 06:14 PM
cycler
Jul 17, 2020 08:38 AM
MikeRC
Oct 30, 2017 01:56 PM
Jimmy Knuckles
Jun 2, 2015 07:57 PM
thewholehog
Feb 18, 2013 09:19 PM
