Lunched my starter yesterday
Old Jun 4, 2019 | 10:27 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
I just got off the phone with Terry Components and they told me that when a starter clutch goes out then you get that whirring sound that I'm familiar with.
That's not the sound I heard.
The sound I heard was more of a grinding sound and was really strange.
When I opened the starter I expected to see some broken teeth on a gear somewhere but they all looked fine.
I'm kinda at a loss as to what went wrong...
Old Jun 4, 2019 | 12:23 PM
Dr.Hess's Avatar
Dr.Hess
Put the starter in a vice, then hook some jumper cables to it and to a battery. See if you make noises or if it just goes whirr.
Old Jun 4, 2019 | 12:37 PM
brad75raiders's Avatar
brad75raiders
Sounds like you sheard off starter teeth either on the gear that rotates the clutch basket or the starter gear itself. I destroyed 2 of those 10-84 gear sets on my 127. Timing was too hot.
Old Jun 4, 2019 | 03:21 PM
texashillcountry
Dirt don't hurt
Don't need to.
True to form I took it apart the second time and found the problem.
For some reason it quite frequently takes me two times to fix something.
That's what I thought at first too!!
What actually happened was a tooth broke off the idler gear (it drives the starter clutch) and found some wear on the armature gear (it drives the idler gear).
Old Jun 4, 2019 | 09:01 PM
1997bagger's Avatar
1997bagger
Starter clutch grinds before it goes completely out, it has fragments of rollers left before they finally quit locking in, have heard that sound quite a few times like 4, it doesn't just start whirling from the beginning.
Old Jun 5, 2019 | 08:33 AM
tas_todd's Avatar
tas_todd
I'm in the same boat with my 94. Fried the starter clutch in my All ***** starter.
Old Jun 5, 2019 | 09:09 AM
Tommy C's Avatar
Tommy C
Always start your bike with the throttle closed. Opening the throttle fills the cylinder and makes the engine much harder to turn over. It increases the dynamic compression of the engine by letting in more air.
Old Jun 5, 2019 | 09:20 AM
texashillcountry
Dirt don't hurt
Just so you know the 111 comes with compression releases.
Old Jun 5, 2019 | 09:21 AM
texashillcountry
Dirt don't hurt
I wish it was just my starter clutch but I found damage on the armature and idler gear so instead of just replacing the clutch I'm replacing the starter.
Old Jun 5, 2019 | 10:09 AM
Tommy C's Avatar
Tommy C
I still wouldn't open the throttle. That's a big gulp of air you're letting in compared to the puny outlet in the compression release.
