Slight popping on decceleration
Old Jun 29, 2019 | 02:34 PM
Windseeker's Avatar
Windseeker
Default Slight popping on decceleration
I mentioned in the other thread HERE that I re-jetted my carb last night. Man, this thing will FLY now! No kidding. I swear it feels like I've gained 10-15 HP. Probably not, but it sure feels like it.
One minor issue: I now get a slight popping on deceleration. Not a true backfire, but a slight popping that wasn't there before. In researching this, most people point to two things, exhaust leak or lean condition.
What's your best guess?
Old Jun 29, 2019 | 02:50 PM
Mattbastard's Avatar
Mattbastard
Back the idle mixture screw out half a turn, assuming you don't have any intake leaks.
Old Jun 29, 2019 | 03:31 PM
Windseeker's Avatar
Windseeker
Thanks, but I actually took it in about a turn and that fixed it.
Old Jun 29, 2019 | 09:39 PM
Mattbastard
What carb you got?
Old Jun 29, 2019 | 10:21 PM
Windseeker's Avatar
Windseeker
What carb you got?
It's the stock CV, but I installed the CV Performance Tuner's Kit with new jets.
Old Jun 29, 2019 | 10:43 PM
Yankee Dog's Avatar
Yankee Dog
What jets are you now running and what mods have you done to the bike (what exhaust, cam, etc)? YD
Old Jun 30, 2019 | 02:36 AM
Windseeker's Avatar
Windseeker
#185 main, #46 idle. I recently installed a K&N high-performance air filter, and the bike had high-flow pipes already when I got it.
Let me tell you, the difference is AMAZING. Before now, I could be doing 60 and get on the throttle and it would take several seconds to reach 70, and that was on level ground. Now it's at 70 very quickly and with plenty more headroom.
Also, this might be my imagination, but I swear the bike has less vibration now, both at idle and when riding.
Old Jun 30, 2019 | 06:22 AM
GOGOBECK's Avatar
GOGOBECK
Good job!! Glad to hear your mods worked out! 💪
These mostly stock EVO’s really run nice when dialed in!
Old Jun 30, 2019 | 10:47 AM
Windseeker's Avatar
Windseeker
I forgot this part: the cam is stock as far as I know.
Someone in the past had already drilled out the pot metal over the mixture screw, so the mix had apparently been adjusted before.
Old Jun 30, 2019 | 12:43 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Sometimes a little rich will get sucked in on d cell and will actually fire off in the pipes, thinking lean but no actually Rich so the fact that you turned in your mixer screw a little bit and it took care of it confirmed it
