Jagg oil cooler system install problem
Old Jul 17, 2019 | 09:11 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Originally Posted by misfitJason
Problem with those is I'm 5'6" and I don't think I'd be able to reach the pegs if I put forward controls on.
Old Jul 18, 2019 | 05:33 AM
98hotrodfatboy's Avatar
98hotrodfatboy
I thought you meant the filter mount... I used the left down tube for the cooler..
Old Jul 18, 2019 | 08:43 AM
texashillcountry
Dirt don't hurt
I did mean the filter mount.
Old Jul 18, 2019 | 04:48 PM
98hotrodfatboy
then there shouldn't be an issue with the way I explained earlier about plumbing the cooler than to the oil filter cuz it's all on the back side of the pump so it really doesn't matter the filter mount is more of a pain as anything else so why even ****ing bother with it.. unless that is you think you need the thermostat in there but I haven't run mine with it and I've never had any issues ever..
Old Jul 18, 2019 | 07:26 PM
texashillcountry
Dirt don't hurt
A friend told me to simply lower the reservoir to under the regulator.
Seems like the easiest thing to do IMO.
Old Jul 19, 2019 | 05:48 AM
flhchaz's Avatar
flhchaz
^^^^^^Hope TD doesn't see that pic. He'll go nuts with all that dirt and grime!
Old Jul 19, 2019 | 06:46 AM
texashillcountry
Dirt don't hurt
If TD saw the complete bike he would die of apoplectic shock!!!!
Damn thing is even dirtier than mine and that's saying something!!!!
Old Jul 21, 2019 | 10:01 AM
1997bagger's Avatar
1997bagger
Noticed the dirt pic also, thought it was yours.
Haven't had a chance to research the Jagg deal and hope you got it fixed, was stuck on trying to fix the 5'6" thing and reaching the pegs
Old Jul 21, 2019 | 06:51 PM
texashillcountry
Dirt don't hurt
That's what 2x4's and zip ties are for!!!!!!!
Old Jul 21, 2019 | 09:01 PM
Dr.Hess's Avatar
Dr.Hess
Why don't you just buy the right oil cooler? Or is the problem a sandwich plate that goes on the oil filter spinon? Harely's don't need that. Just get an oil cooler with a built in thermostat or a separate thermostat and plumb it all in the line between the oil filter and the tank, like God intended. Or in Texas, don't even bother with the thermostat, as you'll only need it for that second week in February when it is "winter." Put a cover over the cooler that week and you're done.
