Oil pressure problems
Old Jul 31, 2019 | 06:14 PM
TRU's Avatar
TRU
Stage III
Default Oil pressure problems
why is my road king shooting out the oil cap
Old Jul 31, 2019 | 06:37 PM
hdvespa's Avatar
hdvespa
My guess would be crankcase pressure. Year of bike and mileage?
Old Jul 31, 2019 | 06:45 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Do you mean... why is oil shooting out the filler neck?
Have you done any work on the bike recently?
Did the issue just start?
How much oil is in the tank?
Are you still here?
Old Jul 31, 2019 | 07:15 PM
TRU's Avatar
TRU
Stage III
I am losing my oil cap dipstick, the pressure builds up then shot guns it out about 15 feet, its a 2004 road king
Old Jul 31, 2019 | 07:16 PM
TRU's Avatar
TRU
Stage III
it has 30k on the miles
Old Jul 31, 2019 | 08:23 PM
Beemervet's Avatar
Beemervet
Probably too much oil.
....and BTW, this is the EVO forum. We know a couple of things, but Twinkies, not so much.
Old Jul 31, 2019 | 08:45 PM
hdvespa's Avatar
hdvespa
Iown an 85 Evo and a 2002 Flhtc twin cam with ss510 cams and 95 inch. I also changed the vent tube that comes acoss into the fill neck to a smaller dia hose. I have the same problem when I get on the throttle hard. I believe the issue is crankcase pressure from that vent line. I fixed mine by making a clamp to prevent the dipstick from blowing out. The newer twin cams switched to a threaded dipstick
Old Aug 1, 2019 | 06:12 AM
splattttttt's Avatar
splattttttt
Threaded oil cap on a newer twin cam? NOT!
Only on sportsters.
For the original poster... Crank case breathers clogged. But can’t imagine why?. Unless metal shavings got in the passages?
Old Aug 1, 2019 | 07:28 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Only on sportsters.
The oil cap is threaded on my `16 Road King...
Old Aug 1, 2019 | 08:09 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Wasn't there an updated version of Reed valves for the breathers to cure that problem?
