Clutch plate replacement question
Old Aug 5, 2019 | 02:27 PM
Scott Ballz's Avatar
Scott Ballz
Default Clutch plate replacement question
I’m replacing the clutch plates on my buddies 98 softail custom and was wondering if it was necessary to loosen the clutch hub main shaft nut, after I remove the adjuster screw? I watched a video where someone loosened it but he also replaced the primary chain. just want to make sure I do it correctly.
Old Aug 5, 2019 | 04:55 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
You don`t need to remove the clutch hub retaining nut.
Your friend, however, needs to buy a Factory Service Manual (not haynes, not chiltons...Genuine Harley Davidson).
lmz5150
EVO
17
Apr 4, 2021 08:55 AM
Ground Hog
Jan 9, 2013 01:22 PM
shopratles
Shovelhead
May 4, 2011 02:45 PM
sdguyman
Jan 15, 2010 09:44 PM
ANIMAL03
Jan 6, 2010 02:09 PM
