Primary Drain Plug "Upgrade"
Old Aug 8, 2019 | 08:45 PM
dixonk's Avatar
dixonk
Originally Posted by RLH3175
My 1996 Ultra Classic's drain plug on the primary would screw all the way though and fall into the primary. I did not want to spend the money for a new cover, so after 5 years of putting up with the drip, I plugged the hole, it doesn't leak a drop, but when I have to remove the primary cover, I remove the chain adjuster cover and take about 3 feet of 1/4" hose and siphon most of the oil out and then take a towel and lay it under the primary then remove the cover. My Norton did not have a drain plug.
I'm almost there. Frustrating
Old Aug 11, 2019 | 08:45 AM
dixonk's Avatar
dixonk
So is there no replacement primary cover available that has the newer style o ring drain plug? Hell I can't even find a replacement stock plug to try out either.
Old Aug 11, 2019 | 09:28 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
I know you can fit up to an '06 outer primary to your bike.
The stock plug is still available at the dealership.
Part number 739A.
Old Aug 11, 2019 | 09:55 AM
dixonk's Avatar
dixonk
Part number 739A.
Thanks. Will probably try a new plug and some tape first. After that the cover is coming off.
Old Aug 11, 2019 | 10:27 AM
NORTY FLATZ's Avatar
NORTY FLATZ
I used the Teflon tape on mine. Went around the plug about 8 times, trimmed the "overage" that went inside. Tight as a drum.
Did this for 21 years.
Old Aug 11, 2019 | 12:52 PM
dixonk's Avatar
dixonk
I never tried going crazy with it.
Old Aug 13, 2019 | 04:10 PM
dixonk's Avatar
dixonk
Ran the **** out of the bike yesterday. It stopped leaking now. Wonder if the oil thickened up with use.
Old Aug 13, 2019 | 04:17 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
You are dreaming...
Old Aug 13, 2019 | 04:26 PM
dixonk's Avatar
dixonk
You are dreaming...
Or maybe pipe tape expanded?
Old Aug 16, 2019 | 05:26 AM
Uncle G.'s Avatar
Uncle G.
I used Hylomar on the threads of the primary and transmission pipe plugs when I had my Evo Softail. Over 200,000 miles and never leaked a drop. Didn’t have to be much more than finger right either.
