refilling the primary question
Old Dec 19, 2007 | 10:41 AM
!!!SPEEDY!!!'s Avatar
!!!SPEEDY!!!
Default RE: refilling the primary question
Anybody try different type oil I read some where that TypeF transmission oil works well. I might try some next oil change. Iput in 1 quart of oil in mine. Might even try mobil 1 syn. atf.
Old Dec 19, 2007 | 11:38 AM
89 FXRS's Avatar
89 FXRS
ORIGINAL: !!!SPEEDY!!!
I use straight 20w in mine. 10w will be ok too. 30w is too thick and do not for any reason put synthetic in your primary. Your primary oil is more a coolant than a lube. If you use synthetic you may or will if you are hard on your clutchburn out your clutch due to the hi lube quality.
santajim
2014-2024 Touring Models
Oct 16, 2017 05:01 PM
Hoosier XLC
Jun 26, 2012 06:28 AM
mwriggs
May 19, 2009 10:11 PM
Reckless Kelly
EVO
Jun 9, 2008 06:00 PM
HDspringer
Sep 23, 2005 09:00 PM
