Cranking Without Plugs
Old Dec 9, 2019 | 10:53 AM
rol427's Avatar
rol427
Default Cranking Without Plugs
My 1991 FXSTC has a Screaming Eagle ignition module. When Spring comes I would like to remove the plugs and spin the engine to prime the oil feed system. Would that damage the ignition? Thank you for your input.
Old Dec 9, 2019 | 11:06 AM
Jackie Paper's Avatar
Jackie Paper
On any system, you should ground the plugs on the wires to the head or just the wires to the head. On a TC, the system does it by sensing no compression and doing it for you.
Old Dec 9, 2019 | 11:40 AM
0maha's Avatar
0maha
Seems like more trouble than it's worth. Why not just leave the fuel off and spin it for five or ten seconds?
Old Dec 9, 2019 | 11:44 AM
nevil's Avatar
nevil
Can't you just pull the leads off the plugs and crank it?
Old Dec 9, 2019 | 11:58 AM
98hotrodfatboy's Avatar
98hotrodfatboy
The only time I do pull the plugs and crank it for thirty seconds maybe 2 or there times with rest in between (to cool the starter motor) is when I do a top end rebuild with lifters.. But yeah you should ground the plugs or leads or disconnect the 12v supply to the ignition system but not really needed..
Old Dec 9, 2019 | 01:27 PM
rol427's Avatar
rol427
Thank you gentlemen.
Old Dec 10, 2019 | 11:31 AM
carlgrover's Avatar
carlgrover
You would be better off priming the oil pump by removing the screw at the top and pouring a little oil down into it. Then just start your bike.
carl
Old Dec 10, 2019 | 01:06 PM
splattttttt's Avatar
splattttttt
Sorry Carl. What screw did you mean?
Old Dec 10, 2019 | 01:16 PM
RANGER73's Avatar
RANGER73
It’s a gravity feed system. There’s oil in the pump. The lifters, pushrods and rockers might be a little dry. So leave the petcock off and bump it 3 times for 2 seconds to get the oil up into the heads.
Old Dec 10, 2019 | 08:55 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Just start the engine.
