Short in harness
Old Jan 1, 2020 | 02:05 PM
Jmcc71961's Avatar
Jmcc71961
Stage II
Default Short in harness
1995 Ultra Glide Classic
68,000 miles , have a short . Lights stay on when ignition is off ,previous owner cut cb harness . This may have been done power on . Is there a place to start. Had mechanic tell me ignition switch , changed no difference, then said it was ecm changed no difference. Please give me some advice on how to trouble shoot this .
Thanks
Old Jan 1, 2020 | 02:15 PM
Dr.Hess's Avatar
Dr.Hess
New mechanic? I mean, lights stay on and the engine's EFI computer are, ahh, separate and not related items. What's his next suggestion? Check the wheel bearings?
I'd GUESS that whoever cut the CB harness butchered up some other stuff. Pull the outer fairing, get a schematic and start tracing the wires starting at the light that is on.
Old Jan 1, 2020 | 03:06 PM
Jmcc71961's Avatar
Jmcc71961
Stage II
Thank you .
The fuel pump kicks on when I plug the data cable in as well as lights on . I can see the do diligence of tracing the short. I will start tearing it down to locate troubled spot. Was riding , bike was fine data cable unplugged bike quit. When I found the plug unplugged I plugged it in that’s when the lights and fuel pump came on with ignition in off position. I noticed the plug was hanging off the ecm home position, I think previous owner probably unplugged it after riding . Bike runs fine alittle rich other than that it’s sweet.
Appreciate your response.
Old Jan 1, 2020 | 04:46 PM
yellowstone kelly's Avatar
yellowstone kelly
68,000 miles , have a short . Lights stay on when ignition is off ,previous owner cut cb harness .....
....Please give me some advice on how to trouble shoot this .
Thanks
As Dr. Hess suggests, you need a wiring diagram (schematic) for your bike, and a VOM multimeter to use in checking/testing your electrical circuits.
My "dream retirement" is to throw a multimeter in a saddlebag and ride around the country to try to help electrically-challenged people fix electrical problems on their bikes.
I'm no genius, but forty-four years of fixing computers and other electronic equipment for a living gives me somewhat of an advantage in figuring out what's going on when something electrical doesn't work .
Jmcc71961, good luck in figuring out this problem. You can do it with the right wiring diagram, perseverance, and help from knowledgeable people like Dr. Hess on this forum.
Old Jan 1, 2020 | 05:15 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Thanks
When you have your schematic and DVM in hand start chasing the head light wires back carefully checking the wires.
Some where the wire shorted to a constant hot or previous idiot connected it in the wrong place.
With the schematic you can find where the wires are supposed to go.
Old Jan 1, 2020 | 05:36 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Pull the lights fuse, do the lights stay on?
If they don`t, start working upstream toward the ignition switch.
If they stay on, pull the accessory fuse, then pull the ignition fuse.
When the lights go out, you will know which circuit the lights are hot wired to.
dloft13
Electrical/Lighting/Alarm
Aug 1, 2017 04:43 AM
hippijim
Apr 3, 2013 11:02 AM
D1gger
EVO
20
Jul 4, 2011 07:03 PM
98glider
Ironhead
16
Apr 28, 2011 02:29 PM
Badbagger
Apr 27, 2008 08:46 PM
