'93 Ultra Rear Cylinder Exhaust Pushrod Removal
Old Jan 2, 2020 | 05:58 PM
drm1978's Avatar
drm1978
Originally Posted by t150vej
Looks like you still have the pushrod cover (fully) installed. (?)
Remove the pushrod cover lock, slide the lower cover up out of the tappet guide, upper tube cover down out of the head, allowing the lower end of the rod to swing inward toward the cylinder. It'll come right out.
If you have taken the engine-to-frame top link loose, you may have to pull the top of the engine toward the cam side to get it out. Especially on the jiffy stand, the engine tends to lean over to the left when the link is disconnected.
Yep! Worked perfectly! Both pushrods are out. Thanks!
Old Jan 2, 2020 | 06:00 PM
drm1978's Avatar
drm1978
Hey tell us about the teardown, inquiring minds want to know.
I like the idea of keeping the one piece pushrods, just make sure you follow the factory service manual religiously when you reassemble the rocker boxes.
If you're interested, I'll continue to post my progress (with pictures) on my other thread titled "Valve Diagnosis"
Old Jan 2, 2020 | 07:50 PM
98hotrodfatboy's Avatar
98hotrodfatboy
I've always just done it this way.. Remove pushrod clip and remove tubes and pushrod all together as one unit, up off the lifter and slid down and out. And just reverse installing.. Slide up and in...
Old Jan 2, 2020 | 08:27 PM
t150vej's Avatar
t150vej
That works too. I just like lifting it upward - working with all that weight against gravity makes me feel macho
Taylor68
Ironhead
Jul 5, 2012 05:00 PM
ride2tires
Sep 27, 2007 05:38 PM
michiganlarry
Shovelhead
Sep 1, 2007 10:41 PM
2005UltraNC
Exhaust System Topics
Jun 10, 2007 02:12 AM
