Replace evo primary
Old Jan 13, 2020 | 08:15 PM
STjohn88's Avatar
STjohn88
Stage II
Default Replace evo primary
I’m putting the primary back together on a 1988 FLST evo and I got this extra part left over. I didn’t take it apart and I can’t find my Manuel. None of the pictures I have found have this in it but it was in the box.
anyone recognize it ?
3” dia. 1” hole
3/16” thick
Old Jan 13, 2020 | 09:43 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Looks like part of your compensator stack.
Old Jan 13, 2020 | 09:47 PM
texashillcountry
Dirt don't hurt
Here it is.. part number 14
https://shop.suburbanharley.com/oem-...0534-H030035/y
Here is a picture
https://www.ebay.com/itm/Harley-2996...-/303140383064
Old Jan 13, 2020 | 10:54 PM
TexNorth's Avatar
TexNorth
Seems like anytime I work on a car, I almost always have a bolt or two left over......I've been guilty of that
Old Jan 14, 2020 | 06:30 AM
Schex's Avatar
Schex
You also should check sprocket alignment, it's way off right now, #8 is the shims to set alignment, goes between the shaft extension(#20) and the spacer that was left out.
Alignment is checked by laying a straight edge across the inner primary housing gasket surface and checking depth to the chain with a caliper, push the chain back, or in, on both sprockets, and compare measurements taken close to the front and rear sprockets, spec is within .030"
Old Jan 14, 2020 | 06:48 AM
Tom84FXST's Avatar
Tom84FXST
Since you didn't take it apart...you need to check alignment...at one point that part was made onto the rotor...then they made it separate...they they eliminated it altogether, and made the shaft extension longer...
If the rotor /stator has been changed no telling whats in there...and checking alignment is the only cure...simple 5 minute check...
Old Jan 14, 2020 | 11:39 AM
grbrown's Avatar
grbrown
Talking
Same here, car or bike, however as left overs go that is a bit big to just set aside for the time being!
Old Jan 14, 2020 | 02:40 PM
STjohn88's Avatar
STjohn88
Stage II
I think I got it figured out. There was a new stator installed. Thanks for the help.
Do you check alignment with everything torqued or just “tight” ?
“You also should check sprocket alignment, it's way off right now, #8 is the shims to set alignment, goes between the shaft extension(#20) and the spacer that was left out.”
Old Jan 14, 2020 | 04:16 PM
t150vej's Avatar
t150vej
No all use that spacer. Many, if not most aftermarket alternator rotors have a thicker "hub" that does not require that outer or an inner spacer. If the rotor has splines, it's aftermarket (and may or may not use spacers). If it's a round bore, it's likely OEM.
You can check chain alignment with the compensator nut snug. The last round or so on the nut just compresses the spring pack
Old Jan 14, 2020 | 04:34 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Check alignment of rear and front spockets measuring off finished face of inner primary. That inner washer the front sprocket sit on is ground OD and both faces. There is an outer washer on that compensator bolt nut but that looks too big to me for that.
hdpeanut1
Mar 17, 2011 10:28 PM
mhuff
Dec 31, 2010 06:40 AM
mhuff
Dec 30, 2010 01:04 PM
classicbowtie
Shovelhead
Jun 10, 2010 02:53 PM
BULL65
EVO
Jun 3, 2008 11:23 AM
