Crankshaft seal
Old Feb 2, 2020 | 06:09 PM
EVOrider's Avatar
EVOrider
Default Crankshaft seal
1998 Ultra.....135,000 miles
Anyways.....been having a little clutch slippage and difficulty finding neutral. Engine oil a little low as well....it’s not burning or leaking.
Today, I removed the primary inspection cover and oil poured out. It was not overfilled during the last service.....approximately a quart.
I’m thinking the crankshaft seal has failed. I’ve never had one go bad before of all the Harleys I’ve ever owned. It is the original on this bike.
Anyone else had these fail?
Old Feb 2, 2020 | 06:28 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Make sure that sleeve in not grooved. Usually, it can be reversed for a new surface. Interesting but as the oil gets full of trash, it imbeds in rubber and grooves the steel. Softer material cuts harder material if there is any abbrasive material. Hence cast iron and copper lapping tools.
Old Feb 2, 2020 | 07:04 PM
Tee&Vee's Avatar
Tee&Vee
One of the easier repairs to do yourself. Only thing to make sure is that the seal seats nicely.
You will get a dozen people to tell you to put the spring inside, you'll get a dozen more saying to face the spring outside.
Old Feb 2, 2020 | 07:16 PM
RDHIGH's Avatar
RDHIGH
I had to tear down the primary to the stator-:then i drilled two tiny holes in the seal 180 degrees apart. Inserted 2 small sheet metal(?) screws i had kicking around- used vice grips to pull it out. It was tight- so i had to tap out with a small hammer on the vice grips.
lubed everything up- spacer and seal- and tapped in the new one with a small punch.
Old Feb 2, 2020 | 09:51 PM
1997bagger's Avatar
1997bagger
Large percentage of the time it's a stator screw coming loose and oil transferring through the holes.
Old Feb 3, 2020 | 06:56 AM
EVOrider's Avatar
EVOrider
I had those screws come lose years ago....there’s a reason not to reuse the screws. Last time I replaced the stator....probably 15,000 miles ago. They’re gonna be inspected anyways since the rotor has got to come out.
I’m probably gonna replace the seal anyways....even if it’s not the problem. It’s original and I’ll be in that area.
Old Feb 3, 2020 | 06:59 AM
Diablo Dainese's Avatar
Diablo Dainese
I had the same issue of oil seeping into the primary. And it was the crankshaft seal. No problems since replacing it.
Bobby Guillory
Oct 1, 2017 05:57 AM
RexBuck
Jan 18, 2011 08:52 PM
toma3729
Oil Archive (no new posts)
Sep 25, 2010 06:04 PM
janiharley
May 20, 2010 02:04 PM
electaRICK
Mar 9, 2010 08:35 AM
