problem with spark plugs
So I recently brought an FXR from 89 with an original engine, ignition module, an Accel ignition coil, and a Keihin butterfly carb.
I´m having an intermittent problem.
The bike starts and after one minute with the choke pulled halfway it shuts off.
I check the spark from the ignition coil, touching a flat screwdriver on one of the "exits" and approximating the tip to near the cylinder head, when everything is OK I see multiple sparks coming from the tip of the screwdriver.
But now I see the 1st spark and then I don't get anymore.
If I turn off the ignition and wait a minute I repeat the process and appends the same.
This loss of spark is common when the Harley is cold after I run it for 5 miles it warms up and I never get to any more problems, I think...
The ignition coil is accusing 3.6 ohms and 11800 ohms, in the primary and secondary circuits respectively.
I also some times have gas on the ground and others not, I have clean the carb and adjust the float to the specified gap.
I also check if I have spark when I touch the terminals from the cam position sensor
I have none.
The other day I remove the paint from the ground connection of the ignition control module and the bike run fine I thought the problem has there but now I don't understand.
I have talked to someone and was advised to check the ignition wiring.
Thanks for any welcome help.
I have none.
When any ignition system produces a single spark then none, it's because there is a loss of capacitance on the primary circuit. (bad condenser on points or magneto system, ignition module on electronic system) You also mentioned in another thread a problem around 90 (kph or mph?) That could indicate a module malfunction.
If you can get it to run until warm and everything is OK, that is a symptom of a (failing) temperature sensitive pickup in the nose cone.
Since the ignition module is no longer available, many, if not most of us have gone to either an aftermarket ignition module using a stock type cam position sensor, or a self contained nose cone module like the Dyna 2ki, Ultima 53-644, Compufire etc.
If you want to fully diagnose what you have now, go to post #10 and post #27 at this link: https://www.hdforums.com/forum/ignit...-no-spark.html
I have another Harley, 03 Sportster, and with the coil from that one, I put on the FXR and then it started. AGAIN Great news.
Thinking I needed a new coil...but because the coil has not well secure I had to stop the FXR and rearrange the coil position.
I disconnected the 4 cables( 2 whites from one point and a blue and pink from the other) from the coil reposition the coil and, AGAIN nothing, no spark.
NOTE: The coil I'm using is from my 03 Sportster and never fails on me. really reliable Harley
The coil test.
I left the white 12v connecter on the coil and with a jumper cable to ground I tried to get a spark and nothing, I saw a small spark on the "negative" of the coil when I removed the jumper. but I never saw a spark.
My conclusion is that the White 12v cable that goes to the coil is not ok, sometimes I have power others not.
I have seen that I can bypass it with a jumper cable that feeds 12v from the battery and test again.
Anyway learning a lot about this FXR.
Is there a post with instructions on diagnosing the wiring?
My ignition module is the original one, it has the Harley reference number.
Thanks for the idea of the cable with the 10 A fuse.
I have the all the manuals and diagrams.
Later I will give some feedback
I have taken the connector for the switch off and on again, stays the same.
Also, the way I put gears on the FXR compared to the Sportster, seems like I have a lot of room in the shift lever.
The Sportster is a bit hard to find the neutral, I need to give it some gas before I can get to neutral but in the FXR the transmission gives the sensation that it has a lot of Freeplay.
Is this normal behavior for the FXR's transmission? Can I do something about the neutral switch?
This is what is on my FXR.
The one in the Sportster has the same 2 input, but only one cable goes into each other.
