Cometic Copper Washer
Old Mar 28, 2020 | 10:30 PM
drm1978's Avatar
drm1978
Default Cometic Copper Washer
Hey folks,
There are 8 copper washers included in the Cometic C9635 top end gasket kit I purchased recently for my '93 FLHTCU. The Cometic part number is RB02002. It's got a 5/8" OD and a 0.262 ID. It's 1/32" think. What are they for?
Thanks!
-Dave
Old Mar 29, 2020 | 05:54 AM
FreedomRider's Avatar
FreedomRider
they are for the rocker box top cover ... you can use either the copper washers or the ones with the rubber seals ... they are there to give you a choice ...
Old Mar 29, 2020 | 05:55 AM
0maha's Avatar
0maha
I had the same question a while back.
They are for the rocker box covers. After talking it over around here, I decided to use them. End up with three layers: Fiber washer then copper then steel on top.
I'm not convinced the coppers do anything. My bike didnt have them from the factory. I assume the idea is that the relatively soft copper will ensure evenly distributed pressure onto the fiber washers. Call it a "Can't hurt, might help" kind of thing.
Old Mar 29, 2020 | 07:41 AM
drm1978's Avatar
drm1978
Thanks!
Old Mar 30, 2020 | 06:21 AM
98hotrodfatboy's Avatar
98hotrodfatboy
I like Omaha use all three, Fiber first then copper then the steel. When using both the fiber and copper, the copper washer works as a slip washer so the steel doesn't tear the fiber washer... Plus I like the way it looks...
lightning95
Engine Mechanical Topics
Aug 23, 2016 11:19 AM
HD Bobber
Exhaust System Topics
21
Nov 14, 2013 10:30 AM
Night Hog
Jul 21, 2011 10:06 PM
jackinthebox
Nov 7, 2010 07:31 PM
bdaug50
Mar 8, 2008 12:54 AM
