Starter question
Old Apr 14, 2020 | 05:55 AM
V-Twins & Bowties's Avatar
V-Twins & Bowties
[QUOTE=Dan89FLSTC;19031829]V-Twins & Bowties:
The `05 starter fit into the opening in the inner primary cover ok?
I have always thought the opening size changed in the `90`s...
Yes , the starters are identical as far as fitting and bolting into the inner primary. On mine anyway.
Old Apr 14, 2020 | 09:29 AM
Tom84FXST's Avatar
Tom84FXST
No.......
1988 and earlier use a different starter configuration, `89 and later are not compatible with the earlier setup.
Actually it was a midyear change...an 89 could have either setup depending on the build date...
Old Apr 14, 2020 | 06:13 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
I have never heard that...
I`ve been buying parts for my bike for over 31 years, there is only part number (inner primary cover) in my parts manuals for 1989 Softail, and that part number is only compatible with the modern starter used in `89 and later.
`89 is its own part number, changes again for `90.
`87 and `88 share a different part number inner primary cover (according to my `87-`90 parts manual).
The starter motors called out for `89 and `90 are the same part number.
The build date on my `89 Softail is `10-`88.
I`ve owned it since new.
It has the modern configuration...
Old Apr 14, 2020 | 06:34 PM
mike131's Avatar
mike131
maybe what screwed me up was the softail primary and starter set up?
fox chaser
General Topics/Tech Tips
Feb 24, 2020 04:11 AM
dwoodlives
Feb 26, 2016 04:17 PM
Tramontin
Shovelhead
May 7, 2014 07:00 AM
Shoopy16
Jul 26, 2012 05:35 PM
hotrod351
Nov 27, 2005 08:16 PM
