I’ve read the threads and made my battery box to move my1990 FLHS battery under the seat. I was at my local indie shop and was discussing this with the owner who’s knowledge I respect, a lot. The maximum width I can get with my battery box and side oil tank is 6” which puts me into a Sportster battery if I stay with a conventional battery. The shop owner said he was convinced I’d go through starter drives due to the lower amp hour battery. Anyone who has done this conversion had starter drive problems post conversion? Of those who have done the conversion, anyone using a 6” wide battery with total satisfaction?
Originally Posted by texashillcountry
You need to talk to Omaha.
Pretty sure Mr Brown did this mod as well. I started it on my '90 Electraglide, but ended up selling the bike. I wouldn't think it's be an issue with todays battery technology.
When I did mine, I made the decision to go with one of the new lithium batteries.
Part of the motivation for that was that I did some engine work at the same time, and bumped the compression a bit. I was worried that a conventional battery small enough to fit just wouldn't get it done.
That's about all I can say about that. The lithium battery has worked fine for a season. Don't know if I could say the same about a conventional battery or not.
As to the stuff about starter drives, I'm having trouble visualizing how that's an issue. But I'm not much for thinking through electrical stuff. What's the theory here?
I'm really pleased with how that project turned out. Mostly because the one-touch bags I installed are so much nicer than the stockers.
Omaha, Do you have the make and model of the battery that you bought? Gbrown, same question for you.
In my case a Shorai, 405CCA. These modern lithium batteries are as light as love, so take care when picking it up, for fear of throwing it over your shoulder!
Thanks.
Frank
Not sure I'd agree with that as you aren't on the starter for that long.
I would be concerned about the battery heating up from all the extra load put on it from the many extra electrical components your bagger has on it compared to a sportster.
Original spec 1990 Glide battery is 20/22Ah. Current replacement 1990 Sporty spec, AGM type, 20Ah, if brand is chosen wisely. No probs! Lithium ones are much beefier still.
A 260 amp battery was original equipment from the factory, so that's what it needs at minimum. Low starting amperage won't necessarily hurt the starter gear, but low cranking amps is murder on the field coils in the actual starter motor.
The lithium 0maha mentioned is about 450 CCA. So if you don't want to do the big bucks for a battery, stay above 260 CCA and you should be good.
