Rocker Cover Gaskets
So, I'm pretty certain my front cylinder bottom and top rocker cover gaskets are leaking. I can see the weeping and moisture from the oil after a ride, and both the front of my AC cover and front of the horn cover are streaked in a little oil. No oil in the AC or collecting in the cover, so not getting blowby, and the rear of the motor is clean. Not coming out of the push rods, and really can't be as the horn cover is getting sprayed too.My compression is 173 front and 170 rear. My set-up is 1996 FLSTN with SE-3 cam, SE AC, SE ignition, RB Racing LSR, and Stock CV with Thunderslide installed by previous owner. 21k on the clock. Scoot runs great, gets up to 48 mpg cruising the backroads and is otherwise running well. If I replace the rocker cover gaskets, besides checking the umbrella valves on this 24 year old, and checking how true the covers are themselves, what else shoud I check/upgrade while I am at it? Also, I've read that Cometic, while high quality, can leak on EVO's, and James gaskets may be a better solution. Feedback here welcome.
Also, with the SE AC, it is vented to the backing plate. With 21k on the clock, is there really any benefit to venting to atmosphere now, or should I just wait until I eventually have to do the top end and new pistons? Thanks ahead for any and all feedback.
