Front end set up
Old May 24, 2020 | 06:45 AM
Adam76's Avatar
Adam76
Default Front end set up
Hey guys, I have just ordered some std progressive fork springs / std height thinking that this would be an improvement over stock..... However since ordering I've done more reading and it seems this modification alone with a an oil change is not going to help me much at all - especially when I'm only 150lbs...
What are your opinions on a moderate front suspension upgrade on a 41mm FLSTN softail ? I could possibly send the springs back if I have to.
I already have a good rear suspension set up in the rear with a custom suited set of YSS shocks. Sorry, just realised should have put this in the suspension section 🙄
Thanks for any advice.
Old May 24, 2020 | 09:14 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Personally I've been happy with my progressive fork springs.
Old May 24, 2020 | 10:19 AM
darylnj's Avatar
darylnj
Default springs
what's your objective? progressive will firm up softail front end. if you want it firmer just go with a heavier oil also.
i have progressive with screaming eagle oil which is 15wt front is firm, you can experiment with different oil weights
Old May 24, 2020 | 04:02 PM
Beemervet's Avatar
Beemervet
40 years with their springs in every bike. I like 'em.
Old May 24, 2020 | 05:20 PM
mike131's Avatar
mike131
Old May 24, 2020 | 06:16 PM
Adam76's Avatar
Adam76
thanks Texas, what bike do you ride and what weight oil did you use in the forks with the progressives?
Old May 24, 2020 | 06:21 PM
Adam76's Avatar
Adam76
hey darylnj, my objective is simply a better ride that soaks up the bumps of the bad roads we have here, as well as good damping control so the ride is smoother and I don't bottom out, and reduce brake dive. All that may be a little too much to ask I have a feeling that 🤔
Old May 24, 2020 | 06:25 PM
Adam76's Avatar
Adam76
Should have stated at the beginning that my objective is simply a better ride that soaks up the bumps of the bad roads we have here, so the ride is smoother and I don't bottom out, and reduce brake dive. Better damping I guess is probably needed to achieve this?
Thanks
Old May 24, 2020 | 07:09 PM
texashillcountry
Dirt don't hurt
'94 FXSTC and a '95 FLSTC.
I run a 10 weight by Amsoil.
Old May 24, 2020 | 07:44 PM
Adam76's Avatar
Adam76
thanks. I think I have the Belray 7w from memory (not at home at the minute).
